You can't really test it like this the wheel with the least resistance will get all the power especially if the the diff is loose already. If you had closer to a locked diff both sides should spin equally. Now the diff is unloading on the wheel with no resistance. You can tear into the gearbox but what I would try first is put the wheel back on tighten the slipper all the way and see what happens. With the VXL and your gearing you should start to wheelie when on the ground with throttle if you do then back off on the slipper. Slipper adjustments can differ from model to model or brand to brand.
