What wheel size is the biggest you can install on the Typhon 3s BLX without damaging any of the parts?
Jackjax801
Pickle Rick!
SLC, UT
Typhon 3s
Difficult to say. You're essentially gearing it up quite a bit and may have ESC/motor heat issues. The additional unsprung weight and grip may break parts that hold the wheel on. Only way to find out is to test it.
suchtragedy
(┛ಠ_ಠ)┛彡ɯɹɐ loɹʇuoɔ ǝʞoɹq
Wenatchee, WA
4x4-Mega, Granite, Infraction, Limitless, Outcast 4s, Typhon 3s, Voltage
2.8MT tires should be fine, the typhon stock pinion is 15T which is the same as the granite with same size tires. If it runs hot then try gearing down to a 13T pinion.
jondilly1974
Speed running apprentice, 3D printing fool
Toledo, OH
Granite, Kraton 4s, Typhon 6s, Typhon 3s
I have tried to run 3.8 tires like the 4S trucks, and they do work up to a point, but it’s not really a great experience IMO. Here are some issues:
- On a full turn the tires may hit the body
- On a landing the chassis won’t slap so something may break
- You will overheat faster
- Wheelies are annoyingly easy, too hard to get any speed
- It looks goofy (see below)
Uplift-RC
Seminole, FL
Granite, Kraton 6s, Notorious, Typhon 3s
If, I am bashing I run the Lock Up skins and run a 20t pinion w/ no heat issues what so ever!!
My Speedruns - I run the hoons with a 26t pinion and I have installed a Yeah Racing Aluminum Case 30mm Booster Cooling Fan which has kept my temps in check!
Create account
Log in
