Arrma15T68
- Toronto, Canada
- Kraton 6s
- Kraton EXB
- Notorious
- Outcast 6s
I don't know but I have a Notorious with 16t speed pinion and am eager to drive one of those 80mph hobbies.
I agree. Seems like the Hand brake is too gimmicky for me. Fluff that wont be used much and just in the way chassis wise. I can see operating the handbrake while in motion will destroy the pads/disc and / or drivetrain. Manual says say not to do that. I think it was more a marketing tool. That handbrake was in the works when they designed the V1 Infr. The chassis always had those 2 extra unused holes for the HB servo mount. Arrma had planned this a while ago.Really? Why would you need a handbrake on something you can easily get sideways by the twitch of your index finger?
I understand that the original intent seems silly, but for speed runs, it would save a ton of heat on the motor to have a brake. I plan on acquiring one for my stretched TyphonI agree. Seems like the Hand brake is too gimmicky for me. Fluff that wont be used much and just in the way chassis wise. I can see operating the handbrake while in motion will destroy the pads/disc and / or drivetrain. Manual says say not to do that. I think it was more a marketing tool. That handbrake was in the works when they designed the V1 Infr. The chassis always had those 2 extra unused holes for the HB servo mount. Arrma had planned this a while ago.
I have no interest in the H brake. I know that once it failed on me, I would remove the whole module anyway. Too much clutter IMHO.
Im curious as to what it actually does. Lock the fronts/rears or all around? Probably a front wheel brake to light up the rear wheels like dragsters do, or perhaps locks the rears like Drifters do. No clue.
I wish someone would show us how it works. The benefit. Fun factor???
You have a good point, if that is how the brake actually works. If It can be used to brake during a speed run, then it is well worth it and has a good purpose. Braking is problem when doing 100mph. The ESC heats up while braking hard. Takes 100ft to stop and all.I understand that the original intent seems silly, but for speed runs, it would save a ton of heat on the motor to have a brake. I plan on acquiring one for my stretched Typhon
... Unless you run a spool ?It locks the rears only and it will be pretty much worthless trying to slow down a vehicle at 100 mph. Can't wait to see it though!
I thought it was just for locking the front or rear wheels while stationary. For hole shots or drifting. I thought that's what a Hand brake was used for in scale cars.
It will send the car flying if used for speed runs! It literally locks up the rear tires and and the whole car goes into a tail slide. Its cool, but like i said in another post, it's all about the wow factorIt locks the rears only and it will be pretty much worthless trying to slow down a vehicle at 100 mph. Can't wait to see it though!
I run locked diffs all around so any brake will brake all four wheels at once. And I’m not going to use the brake on 100%. It would be used at a 10% rate to slowly brake. It would just save the motor from the heat of braking. You then could do another pass much more quickly.It will send the car flying if used for speed runs! It literally locks up the rear tires and and the whole car goes into a tail slide. Its cool, but like i said in another post, it's all about the wow factor
Hope it works!I run locked diffs all around so any brake will brake all four wheels at once. And I’m not going to use the brake on 100%. It would be used at a 10% rate to slowly brake. It would just save the motor from the heat of braking. You then could do another pass much more quickly.
For the $35 it’s worth a shot. These motors get super hot sometimes and it takes 10-20 mins to cool them off. I sometimes have to bring a spare pack just to run fans.Hope it works!
I was giving an example. Haven’t tried it yet. That’s where I will start and see what works. I’m not going to disable motor brakes either. Still need those in an emergency maybe. The idea is a better way to peel off speed and save the motor heat.If it works on a single disc locked I'd go more than 10%.
Thanks for the info. I wasn't sure which wheels it would control. Makes sense now that it would not be realistic for high speed braking. You will end up flat spotting the rear wheels at high speed. Uncontrollable IMO. Rear brakes does nothing to stop a vehicle. You need all 4 wheels to stop. I could see ABS being used with an appropriate Channel Mixing capable Tx and Rx and some modding.It locks the rears only and it will be pretty much worthless trying to slow down a vehicle at 100 mph. Can't wait to see it though!
I'm with you. I wouldn't remove it if I bought a V2 Infraction, but I'd never use it.It seems like a cool idea for about 10 seconds, but I wouldn't want a handbrake on there anyway. To me its extra unnecessary weight with little benefit and something else to break
I would probably replace the Radio/Rx anyway, and yank it out knowing myself.I'm with you. I wouldn't remove it if I bought a V2 Infraction, but I'd never use it.
