A 9000 mah pack is heavier than a 5000mah pack. That’s all I was saying.same weight as two 3s
These are toys? Hmmm , interestingno two 3s packs,yes its a big battery.im noT RACING nascar its a toy.i really like the 6s,and this one battery weighs 1.48 pounds
Uh ohThese are toys? Hmmm , interesting
Expensive yes .TOYZ HMMM INTERESTINGexspensive toys,Lol
Yes, toys.Expensive yes .TOYZ HMMM INTERESTING
Yea but if I remove the core from those green apples, can I fit them into that aluminum can?
InterestingYes, toys.
What's so interesting about that?
ToyI don’t think that’s exactly correct. This says (1.14 ea) so that‘s 2.28lb for 2 9000mah 3s vs 1.48 for 9000mah 6s.
All this new stuff means nothing. I would consider the added weight a burden on my shocks and chassis. And you’re right it is a toy that you should have fun with it. That’s The important part.
Interesting
No, that is not correct.You know that it will not run that combination. When you go to plug that in and turn it on, you should really be outside and I hope you have a fire extinguisher handy.
Just don't listen to this guy!!No, that is not correct.
Nothing bad it will happen.
Just the car wont move, and only the steering servo will work.
Twice i have pluged 7s batts to 6s esc's without problem.
