10pas2
View attachment 16014 This seems like a good idea to try an Brace the wing
Genius!!! How is working out?!
This is an image I found on this forum thought myself it was a great idea. It's one I'm going to try but have not yetGenius!!! How is working out?!
Wow you guys work fast. What are the parts called so I can do the same.
I have been using the rpm mounts with no issues.. mostly. They are a bit tweaked but haven't broken. As for a wing, I'm using the Outcast wing. It's seen some abuse and hasn't broken yet .
I have tried the braces and ripped the screws out of the gearbox and other havoc. The best thing so fat is rpm wing mounts. When they bend boil them for two minutes then reshape them. Doing this to my current wing mount it has last for about 5 batteries. I also plan a little more before I jump. Always be able to see where it takes off and lands.
I have a more permanent solution but it is in the works and I think will keep the wing mounts from breaking at all or seldomly.
What kind of jumping are you all doing to break these wings, is it cold weather related?
The Tekno wing has lasted the longest so far.
The Yeah Racing YA-0284 looks nearly identical to the Tekno wing, it looks like the Tekno wing has pre-drilled holes ?
While the Yeah Racing doesn't.
