- Infraction
- Kraton 6s
- Mojave EXB
- Senton 3s
Good luck my guy!
Yeah I don't think it is necessary. Two castle setups running moderate is 12+ hp each.Thanks liberty.
i hope this build hits my goal, i really don't wanna go dual LMT, thats expensive.
like really expensive.
So we should get more tiresYeah I don't think it is necessary. Two castle setups running moderate is 12+ hp each.
I doubt the tires can find enough traction to do anything more.
That’s what i think. If raz is doing 198MPH on 2 1717 motors, and thinks 210, 2x 20hp 2028 motors will fit the 200+ bill
by the way, does a 1717 actually have 15HP ???
and does the 2028 have 21?
OMG SOMEONE SAID IT!!
yep, 15hp esc, 1.5hp gone like that.
98 percent efficiency through the gears.
call it 95 percent for diffs
95 for ceramic bearings.
so yea 12hp for a 1717 sounds right, meaning 48hp RC car for raz.
lets run the same math for the castle 2028.
I’ve seen about 14.5kw from my 2028, if you run the same math that means its final power is..
Meaning about 11.5 kw per motor, run 2 and you get A REAL 30hp RC car.
more things to consider is raz (on the quad) is running a 35 percent meshed spur, drop another percent.
also, hes only running 12S. That the equivalent of running my 150mph typhon on 3S.
This is where my bid comes into play. A 47hp quad motor RC car running a fraction of the voltage it can run, versus a 31hp RC car running as hard as it can.
another note, i might go to 1721 motors if these cant do it, but i think they can.
@LibertyMKiii do you agree with this?
I agree it needs more KVYea, but when’s the last time you’ve seen one of those?
i really think the best speedrunning motor would be a custom rewound 2028 to about 1800kv.
5870 is a 6 pole motor.I know, that why i think if 2028 motors don't do it, maybe some 5870’s ?
Also @LibertyMKiii was the backflipped CF body yours?
It's what makes finding the perfect road hard. When you think youve got some place perfect it's these details that can completely disqualify a seemingly perfect road...Alright, so i ran it on my 1400 feet long road, and it went alright, the whole time i was on 6s, 1100kv, xlx2, aah you know the drill. First, i ran a 77mph warmup pass, then i did another pass to try to push harder, aannd i had a blow over. Here’s how it went, and i would want you guys to read it so if something happens to you, you might be able to look back on this, and get an idea why it happened.
so my road is like a dish, with a lip at the very end, and when you get the car all the way back, you speed up on the 100m slight downhill section, then on the 200m flattest portion (its all still very flat) you can hit your 100+ speeds, then when you are slowing down in the last 100m you lit a lip, like a ripple in the road, not a speed bump, but just enough to throw the car off, and spin out, i spun out at 86mph, not half bad for only using about 40 percent power.
