slick2500
Anything will break if you drive it wrong enough.
Community Leader
ArrmaForum Fan
- Rapid City, SD
- Fireteam
- Kraton 6s
- Kraton EXB
- Outcast 6s
- Senton 3s
- Typhon 3s
What size are the groms tires? I cannot find the specs on them.
These trenchers are 92mm i believe. 1/16 but I'd be putting my money on them fitting well? Maybe?
If the Grom is similar to the Ecx Ruckus in dimensions the Trenchers will fit only if you limit the steering.
They hit at full lock and when the front socks are fully compressed. As do Merv wheels and tires.
They also look out of proportion from the rest of the truck.
This is what the Arrma Gigasite says but that cannot be right. The Granite 4x4 has 4.92" tires on it.
TIRE DIAMETER
125mm / 4.92"
This sounds right though.
WHEEL BEAD DIAMETER
47mm / 1.85"
