If both motors have the same kv and both are the same size in mm (one wider and one longer) is there any advantage with one over the other? More torque or speed??
And by stronger more torque right?I'm going to say speed and torque. That seems to the correlation with motor cans. Length=kv and diameter=torque. Yet that isn't set in stone. But for the most part, one will be faster and the other will be stronger.
Speed is the same since kv is the same.If both motors have the same kv and both are the same size in mm (one wider and one longer) is there any advantage with one over the other? More torque or speed??
RC Explained is awesome! Here is the video explaining motor diameter vs length. It was really informative on this exact topic.Speed is the same since kv is the same.
Diameter impacts torque more than length does, surface area being equal. The bigger diameter can will have more torque.
“RC Explained” on YouTube has some good videos on the topic.
Thanks I’ll check it out!Speed is the same since kv is the same.
Diameter impacts torque more than length, surface area being equal. The bigger diameter can will have more torque.
Thank you!Bigger can will run cooler also. More surface area of the can = a larger heatsink.
I agree the xo1 motor runs super coolThey will probably feel relatively similar, with the 4985 likely having a slight edge in torque. There are a few other variables in play as well, like whether they are from different companies, can length for cooling, etc. Some companies make good quality motors, others are just adequate.
I do like that you can stick two 40mm fans on the 4292/4092 side by side and not have to worry about the position of where the wires come out of the motor.
Perfect thank you!RC Explained is awesome! Here is the video explaining motor diameter vs length. It was really informative on this exact topic.
Think of the diameter of the motor as length of the lever arm. The longer the lever, the more torque. Think of the length as how many of those lever arms are applying torque. So it can be a narrower motor can, but if it is longer it can have the same torque.
