ARA330569Do you have the arrma part numbers?
ThanksI’d just go with the Arrma part but that’s just me.....I found part number 330569 at the LHS. Contains 4 shock rod ends and 4 spring perch’s , .....cheap.
Mentioned above, but the full part number is : ARA330569
3 times now... let’s start a counter .... if this is anything like a Talbot comment section it’ll get asked about 160 more times ????ARA330569
Thanks
I don’t think anyone mentioned shafts ?I have that part and does not come with shafts .
Some are AR some are ARAI don’t mention ARA because it’s assumed....
