Figured I have enough spare parts to build at least 2 cars.
Those parts should be just right to build one.
Funny story... all mine were kinda that way. I went the long way around and bought all my pieces separate. ??Woohoo!
Love a good spare parts car build.
Jerry
Long wheelbase? Stretch a typhon...
What is the little one? Tacon Valor?
Built the diffs today.
80k / 200k / 60k
Spiral cut (Kraton/Outcast) gears.
Front and rear have GPM cups, center hot-racing.
Internal gears and shims as well as the outdrives are Mugen MBX7.
Lubed and shimmed in their new homes.
I will be using the Mugen MBX7 drive shafts that I had in my Typhon.
I would use stock mounts, and GPM only for the front upper... the GPMs created more slop on the front lower and rear arms for me, and the delrin inserts in the rear oval out and wear too quicklyFor the hinge pin holders I'm not sure if it's better to use the stock composite parts (with 7075 inserts in the rear) or use the GPM parts.
Any suggestions, which would be the more rigid solution?
Those shocks look awesome... I'm actually looking for some upgrade shocks for my 3s Typhon. Reckon these will fit it? Do you have part numbers for F&R?Reverted the hinge pin holders to stock and installed lower arms and shocks.
View attachment 81082View attachment 81083
Same in the rear, but forgot to take a picture.
I have used some turnigy shocks that are shorter than stock Typhon.
This allows the car to bottom out with this shock tower and the wheels I'll be using (while still having decent ground clearance).
Thanks very much... yep I've given that thread a good read. I've seen the Trackstar shocks but not with the black shock caps, they look greatI was slightly wrong about the shock brand. It's Trackstar shocks bought from hobbyking:
Front 90mm, rear 106mm with corresponding standoffs, shock boots and black shock caps.
My setup with 90 / 106 mm might be a bit too short for the 3s Taphon. There is also a 126 mm shock set, but 106 / 126 may be a bit too long.
From what I read in the thread Arrma 6s, Arrma Mega 4x4, BLX 3s and BLX 4s shocks upgrades and information, the 3s shocks are 100/115mm.
That thread could have some useful information for you.
