ARRMA TYPHON 6S BLX STREET MODIFIED
Mortuus048
Bronx
  1. Typhon 3s
Hi everybody, Some photos of arrma typhon 3s project.
It looks ready to burn some rubber..
Just need to add some drag chutes and you'll be complete. 😜
I'm waiting for some more parts to go out and run it, for now I'll try the motor and esc that it comes with and then I'll put a higher capacity one
Well don't tease us like that, take your top off! 🤣 Yes I mean the rc's top 🤪
What do you mean, I don't understand you?
Looks like you practically max-ed out your preload clips on your rear shocks...
Perhaps you should use my custom single preload clips Instead.
can you show me?
Don't nobody understand me man.. probably for the best!
🤣🤣 I meant the body man! A shot of the buggy with the body off! You know, showin us the goods underneath 🤣
List of parts
The parts that I have with me:
GRP Mounted Belted Tires White Slick
Spektrum RC 3S Smart LiPo Hard Case 50C Battery Pack
Arrma Vendetta 4x4 3s BLX Front Rear Bumper Set
50T 0.8 M SPUR Gear Slipper Clutch Assembly For Arrma Typhon 3s
Carbon Fiber Drag Race Wheelie Bar for Arrma 1/10 VENDETTA
Aluminum Center CVD Driveshaft W/ Spring Arrma TYPHON
The parts I'm waiting for this week
Alloy Center Driveshaft High Speed Support Set for 1-10 ARRMA 3S 4S BLX
Arrma Mojave EXB 1/7 6s BLX Center Brace Bar with Mounts Red Aluminum Shaft
Hot Racing ATF160B02 Complete 22-Piece Aluminum Pivot Ball Set Arrma
32P M0.8 5mm Black Steel Metal Pinion Motor Gear
Taillights Red + Front Spot White Light for Arrma Typhon 3s Plug & Play
The parts that will come later
Carbon Fiber Side Skirts Left/Right Aero Panels Upgrade for Arrma Vendetta 3S
Sleek Carbon Fiber Front Splitter with Side Winglets for Arrma Vendetta
Enhance Your Arrma Typhon 3s BLX with Carbon Fiber Wing Spoilers Superior
Billet Machined Suspension Kit for Arrma 1/10 Granite 4X4 3S BLX
Hot Racing SCX313TL01 Aluminum 4-Link Set 12.3" Axial SCX10
Hot Racing ATF48SH02 Arrma 1/10 4wd 3s 4s Aluminum Fixed Link Servo Saver
Powerhobby Aluminum Bearing Steering Bellcrank Arrma Typhon 3S BLX
Hot Racing ATF11Y02 Aluminum Differential Yoke Set
Hot Racing Aluminum Differential Carrier Case
RCAWD 37T Diff Differential 13t Input Gear for Arrma 1/10 Granite Big rock 3s
Hot Racing Arrma 1/10 3S 4S Steel Differential Planetary Gears
Team Associated Factory Team 100,000wt 100k Silicone Diff Fluid
ARRMA 3S BLX TYPHON BIG ROCK GRANITE KRATON 4S GPM ALLOY MOTOR MOUNT
Hot Racing ATF288RC Arrma 1/10 4x4 3s Granite Senton Typhon Steel HD Driveshafts
Hot Racing Aluminum Splined 17mm Hex 6mm Offset Hubs
Aluminum F&R Shock Absorber Brace Mount Kit for ARRMA Typhon 3s
Pro-Line 6359-00 PowerStroke Front Shocks Arrma
Real Carbon Fiber Air Intake for Traxxas
Pro-Line 635904 Front Spring Assortment
Colorful RC Car Truck Chassis Body LED light STRIP TUBE Bar Drift 1/10
Castle Mamba Monster X 6s & 1512 1800kv QS8 Attached Motor Combo RTR
Carbon Fiber Steering & Suspension Link Set for Arrma Typhon 3s
Hobbywing ESC Program Box Cards Bluetooth Wireless OTA
Hot Racing NRO10N02 17mm Serrated Close End Dirt Shield Wheel Nuts
Colorful LED Light Bar Strip Roof Lamp
Arrma Typhon 3s / mega Gopro Mount 3D printed Thumbscrew included
Flysky Noble NB4 2.4G 4CH Transmitter Remote Controller w/ Receiver
Brightest LED light KitFits Any Buggy ARRMA TYPHON 6S 3S
ARRMA dBoots Hoons 53/107 2.9 Pre-Mounted Belted Tires Silver 17mm Hex 5-Spoke 2
RCAWD Alloy Body Post Set For 1/7 Arrma VORTEKS TYPHON 3s
Arrma Typhon 3S GPM 7075-T6 Aluminum Rear Brace. 3S/4S
Arrma Typhon 3S BLX V3 Ceramic Sealed Bearing Kit
little by little, the buggy already run with the little I did and it's faster, only the engine and esc are getting very hot but I know I have to change them, for now I'll run it like this until it burns, explodes or dies hurt.
can you show me?
Sorry I missed your request.
Here's what I was referring to >>
They have an inset to better 'cup' the stock shock cap (in red)
Fronts @ 5mm
Rears
@10mm
If you need a different Pre-load clip size/length just PM me ,let me know.
Yeah we don't like skirts ,just what's underneath 🤣🤣🤣
