Aluminum diff cases?
Discussion in 'Kraton' started by Killer Kraton, Jun 9, 2018.
  1. Killer Kraton
    Killer Kraton Well-Known Member
    Apr 12, 2018
    59
    19
    USA
    Arrma RC's:
    Kraton
    Are the Gmp as good as HR?
    I keep having diff problems and would like to solve them. Not sure what broke this last time...haven't pulled it open.
  2. ThatDrewGuy
    ThatDrewGuy Premium Member!
    Apr 18, 2018
    62
    25
    Chicago Area
    Arrma RC's:
    Granite, Talion, Typhon
    I have had good luck with both HR, and GPM parts. In the case of say a diff cover, the GPM is about half the price as the HR one. I have not changed the diff case yet, but did open them all up and change fluid weight. If they start to leak, I will be buying the GPM covers. I mean it’s 3 diffs per rig. 32 each rom HR, or 16 each from GPM.... you tell me
    https://www.gpmparts.com/arrma-krat...tial-case-5pcs-set-gpm-mak011-p-90084816.html
    JeanvdBerg likes this.
  3. joostin420
    joostin420 Well-Known Member
    Sep 21, 2017
    261
    172
    MA/NH
    Arrma RC's:
    Fazon, Kraton, Nero, Outcast
    I went with the HR diff cups and other parts since they are machined and not cast.
  4. slick2500
    slick2500 Well-Known Member
    Aug 21, 2017
    1,388
    498
    Rapid City, SD
    Arrma RC's:
    Outcast
    I have not had much luck with GPM Racing stuff, I am 1 for 4 for getting something that wasn't junk or made incorrectly.
  5. dpricenator
    dpricenator Premium Member!
    Premium Member Excellence Award
    Oct 25, 2016
    1,140
    927
    Arrma RC's:
    Kraton
  6. joostin420
    Sep 21, 2017
    261
    172
    MA/NH
    Arrma RC's:
    my daughter ran her outcast first time last weekend. I was mounting fan on the motor and during inspection i noticed rear diff input area and on chassis was a bit of dirty diff fluid; also at the center diff and pinion/spur. it was only run in a parking lot. I checked my project tomahawk kraton and found nothing, totally clean.
    the difference = tomahawk kraton was a complete ground-up build from new-in-box with all 3x HR diff cups, shimmed diffs, front/rear HR bulkheads, and fast eddy sealed bearings. also, thicker diff fluid 60k/200k/30k.
  7. TheLectrician
    TheLectrician Well-Known Member
    Feb 6, 2018
    40
    28
    Lebanon,pa
    Arrma RC's:
    Kraton
    I have the gpm cases and i love them. Its a full aluminum case and all parts are included unlike HR. Neither one comes with that little piece that mounts the the wing mount and chassis brace tho which sux dong but the GPM is more complete and quality is high. Get'um.
  8. Killer Kraton
    Apr 12, 2018
    59
    19
    USA
    Arrma RC's:
    Kraton
    So the HR ones are machined and Gpm are cast? Thats no contestfor me! Thanks... i think i could get away with front and rear only. Use the original in center. I have thought about that direct drive center spool for center. Keep it level more...
  9. Killer Kraton
    Apr 12, 2018
    59
    19
    USA
    Arrma RC's:
    Kraton
    Anyone using a center spool? I have been thinking about it.
  • Welcome to Arrma Forum
  • Disclaimer
