- ST.LOUIS
- BigRock 4x4
- Mojave
- Notorious
- Senton 6s
- Senton 3s
- Typhon 6s
I've been very impressed with 3650..getting body for other car today.i plan on pushing it with other car..at 107mph motor was surprisingly cool.didnt even pull 4500w with 4060 on 116pass..excited to push the motor to its limits..hoping to play with timing since it's a 2y at some point..I think it'll do better..vendetta was a little squirrely with 400 gram motor...compared to 5660 its 1.2lbs lighter in car..It is going to be interesting to see if that 36mm can will be able to run past 120 mph where the wattage required starts to get higher. The motor only being rated to 4500 watts could be a limiting factor. If you start seeing considerably higher motor temps with less additional speed then you know it's reached the limit and is only throwing the watts into heat versus motion.
