Spitfire222
- Typhon 3s
- Vorteks
This is the fastest and most technically advanced 1/10 scale 4x4 vehicle in the ARRMA lineup.
Arrma Vorteks Features
- Stadium truck body with tough, injection molded wing and protective roof skids
- Adjustable body mounts
- High-traction, vented dBoots® Katar™ multi-terrain tires mounted to tough, gun-metal color wheels
- Spektrum™ 3660 3200Kv brushless motor with ARRMA® heatsink and cooling fan and Safe D pinion
- Spektrum™ Firma™ 100A Smart ESC
- Spektrum™ 2.4GHz DX3 transmitter and SR6200A receiver Smart radio system with AVC® (Active Vehicle Control®)
- Spektrum™ SPMS651 metal-geared servo
- Strong composite chassis with extended height dirt defenders
- Easy-access modular design
- Adjustable turnbuckles
- Steering system with stone clearance
- Adjustable ride height
- Wheelie bar
- Rubber shielded bearings throughout
- Durable 37T 1.35 module metal differential gears and silicone O-rings
- Castellated slipper pad and sliding gear mesh
- Plastic locknut for slipper
- Double wishbone suspension front and rear
- Oil-filled shocks with silicone O-rings
