Outcast Arrma Wheel Hex can't get pin out on Outcast
AussieRc
  1. Outcast 6s
Can't get the pin out on Arrma Wheel Hex on my Arrma Outcast . I'm pushing it out and it still won't budge and I took out Set Screws in the wheel hex.
It's either loctited from the grub screw or they screwed the grub on so tight that the pin bent, or both. Apply flame to the grub screw area & use a punch.
Okay I'll try that and see what happens . Thanks
Pretty common problem, if you can even call it a problem at all. Some heat and use a punch or awl to tap it out. Arrma using tons of Red TL on the hubs set screw may contribute to that.
Yeah I got the pin out now . Now the hubs are stuck
Same here on Senton 6S. My problem is that I could not even get the inside lil screw out first pfff. It broke inside trying to get it out, the screwdriver turns freely inside now. Red TL issue grrr. So I left it and sod it I punched the ping out and it came out. I used a vice to keep wheel hex piece.
