The brass worked great for me with Proline tires, had a harder time with Backflips, had to really sharpen brass with razor repeatedly, still was hit and miss getting a clean hole. Did getter done though.View attachment 6607 New Arrma backflips came in today. I see several different ways to vent them and plug up the wheel vent. The 3/16 brass seems like the best way to do it. Am I correct? Or is there a better way to do it?
You won't believe the traction those will get, but will wear fast on harder surfaces. I use a little grinder bit on my Dremel, not sure what it is called but makes nice clean little holes.View attachment 6607 New Arrma backflips came in today. I see several different ways to vent them and plug up the wheel vent. The 3/16 brass seems like the best way to do it. Am I correct? Or is there a better way to do it?
Does the bit look like colored stone cylinder or metal. I'd like to try that on my 1/10 scale wheels first.You won't believe the traction those will get, but will wear fast on harder surfaces. I use a little grinder bit on my Dremel, not sure what it is called but makes nice clean little holes.
Little metal bit with file like teeth, I will snap a pick tonight when I get home.Does the bit look like colored stone cylinder or metal. I'd like to try that on my 1/10 scale wheels first.
Thanks bro, appreciate it.Little metal bit with file like teeth, I will snap a pick tonight when I get home.
I used the pointed tip on my soldering iron for the tires on my Nero.
Worked great. No more water stuck in my tires...
Must be your bits working, maybe mine are too dull, tried a while back but just plunged through, no clean hole.I just drill a hole why am i the only one lol
Ditto that, too. Think the Backflips rubber compound has something to do with this.Same here. I also tried the hot soldering iron and the holes where never clean. I was also afraid of burning up my foams...lol.
Keep forgetting to send a pick, I will try tonight.Thanks bro, appreciate it.
It's all good bro, mine are vented already. Pretty sure I know what grinding tip you're referring to. I'll try it out on older tire set. Rebuilding Kraton today, finally got everything but front turnbuckle links. Amazes me what critical parts end up on backorder....Lol.Keep forgetting to send a pick, I will try tonight.
You would think with the popularity of these vehicles they would keep us well stocked!It's all good bro, mine are vented already. Pretty sure I know what grinding tip you're referring to. I'll try it out on older tire set. Rebuilding Kraton today, finally got everything but front turnbuckle links. Amazes me what critical parts end up on backorder....Lol.
I was going to try Traxxas links out of desperation, against my better judgement of coarse, think they started bending when I looked at them....Lol, too small and weak at the threads.You would think with the popularity of these vehicles they would keep us well stocked!
