Rear Axle snapped on the senton, not too sure why. The hit was not that hard in my opinion. Did end up cracking my cheap hub too. Lmk what your thoughts on just putting super glue on the hub & calling it a day
Just finished glueing it, it looks decently solid but i am going to a hobbyshop tomorrow to get replacement parts :/Glueing might get you by for a few runs but I would order another hub asap.
Honestly I haven't seen anyone break one of those beforeRear Axle snapped on the senton, not too sure why. The hit was not that hard in my opinion. Did end up cracking my cheap hub too. Lmk what your thoughts on just putting super glue on the hub & calling it a day View attachment 347606
I feel as though thats a complimentHonestly I haven't seen anyone break one of those before
I guess when you put it that way.. yeah"Barelyhit the curb..."
Sir, I found your problem.
Just remove the first word in your title. And that's why your wheel behaved like that.
I am getting replacements but I did glue it $40 tires off amazon, what could go wrong, right? these tires were mostly to mess around with. Yes, I know them breaking was my faultSheshhhh….
Don’t glue anything. Replace only.
Looks like it broke right where the pin goes through the axle shaft. The Traxxas Slash has the same weak spot. Just get a few spares and some extra pins. It should be an easy fix.
That was some detective work man! and yes I will be buying spares todayLooks like it broke right where the pin goes through the axle shaft. The Traxxas Slash has the same weak spot. Just get a few spares and some extra pins. It should be an easy fix.
Get a pair of replacement steering knuckles from Integy, that axle stub is cheap from the factory but I have no idea where to get stronger ones. I just tore one clean off my vorteks just rocketing down the street.Rear Axle snapped on the senton, not too sure why. The hit was not that hard in my opinion. Did end up cracking my cheap hub too. Lmk what your thoughts on just putting super glue on the hub & calling it a day View attachment 347606
I have a Slash, so I've broken a few. It looked exactly the same.That was some detective work man! and yes I will be buying spares today
Wow really? they need to make them out of stronger materials lol.Get a pair of replacement steering knuckles from Integy, that axle stub is cheap from the factory but I have no idea where to get stronger ones. I just tore one clean off my vorteks just rocketing down the street.
It probably could be done! Thats a greatidea! Maybe even kratons?I have a Slash, so I've broken a few. It looked exactly the same.
You might be able to swap the hub/axle from a larger rig? I'm sure it's been done.
