jerseydrew
Is it worth swapping out the bushings for bearings? If so arrma or amazon?
Yes, get the Fast eddy bearing kit.Is it worth swapping out the bushings for bearings? If so arrma or amazon?
+1 FastEddyBearings great bearings plus they are local for me.Is it worth swapping out the bushings for bearings? If so arrma or amazon?
I agree about the bearing.
I wonder why no bearing to start with? Because no complete rotation???
Looks like the left side of bellcrank (non servo saver side) has a TON of play up and down making the steering quite sloppy.
I have the Kraton 6s V5 RTR and im looking to replace those bushings to bearings. Anyone what exact size bearings are an exact fit?Yes. Bocca bearings are what I recommend.
Just get the fasteddy set.I have the Kraton 6s V5 RTR and im looking to replace those bushings to bearings. Anyone what exact size bearings are an exact fit?
I don't need an entire set of bearings for other parts (I have some bearings already). I just need the correct size so I can order them from jimsbearings (can only the exact sizes and quantity needed).Just get the fasteddy set.
Unsure but you can check the exploded views for exact measurements.I have the Kraton 6s V5 RTR and im looking to replace those bushings to bearings. Anyone what exact size bearings are an exact fit?
Edit: Does 6x10x3mm sound right?
Yea the sizes from the fasteddy link I provided are the same size of the brass bushings from the kraton explody view, but I just don't know if that would be correct size for actual bearings to fit in the same slot. I would assume so, but thats why im on here asking lol.Unsure but you can check the exploded views for exact measurements.
