Moogy
Hey guys, I have had my vorteks for about 2 weeks now. I'm want to change the diff oil.. just wondering if anyone on here can help me out with some options please.
Cheers
Cheers
Cheers thanks for the reply.There is no best diff oil. It depends on preference. You need to know what you want to change. Diffs allow the two wheels they're connected to spin at different speeds. Spinning at different speeds helps you turn. Heavier diff oil makes the two wheels spin at closer to the same speed. Heavier diff oil provides more equal power to both wheels, which can increase traction, reduce spinning out, and help the car accelerate better. But too heavy and you'll start to reduce your turning. As a general rule, heavier diff oil in front helps you accelerate without spinning out coming out of turns. Heavier oil in the rear reduces sliding out when going into turns.
Do you spin going into turns, coming out of turns? Do you mostly drive straight line, or do you like to turn and spin a lot? Heavier oil is better for traction and acceleration. Lighter oil is better for tighter turning.
For the Arrma 3s line, people use 10k-50k, often heavier in front. Stock is 10k front and rear. Search RC differential oil tuning. There are many guides on the internet. These are the first 2 that came up for me. Then experiment with these tips in mind.
https://www.bing.com/search?q=diffe...57j69i64.8280j0j1&pglt=43&FORM=ANNTA1&PC=DCTS
https://www.radiocontrolinfo.com/differential-oil/
2k and 10k aren't going to feel much different. Diff oil goes all the way to 25million wt.I find that the 3s diffs don't really behave like a normal (bevel) diff in terms of effect of oil viscocity, already at 2k it feels as heavy as 10k... i ended up putting grease on my rear diff as i tried to make it feel lighter and no matter what oil i used felt as heavy as the 10k at the front..
did someone here tried different viscocities and had other experience?
I see what you mean.I find that the 3s diffs don't really behave like a normal (bevel) diff in terms of effect of oil viscocity, already at 2k it feels as heavy as 10k... i ended up putting grease on my rear diff as i tried to make it feel lighter and no matter what oil i used felt as heavy as the 10k at the front..
I tried 20 front and rear and it worked well. It provided more controlled wheel spin/slide than 10k. I like to spin/slide, so I'm currently running 10k, but I'm thinking of going back to 20 again. In any case, it's a fine place to start. If you want to spin/slide more, go lighter, if you're still spinning/sliding too much go heavier.I was thinking of going 20 front and 20 rear
