Welcome, can you tell us a little bit more about where you would like to run your rig? Do you plan on racing or bashing? Jumping off road vs racing on road? First RC car? These things will help us point you in a better direction.Hi guts,
which RC can you recommend in terms of price and range? Looking forward to an RC System with receiver with internal antenna and sender with normal batteries ...
Greetings,
Thomas
Onroad ... speed run ... first RC car ...Welcome, can you tell us a little bit more about where you would like to run your rig? Do you plan on racing or bashing? Jumping off road vs racing on road? First RC car? These things will help us point you in a better direction.
Infraction would be a good place to start. Out of the box, it will be set up for speed on the road, and it will be very fast with no mods or just a pinion change. Typhon would also be good, but it really is an offroad car, with offroad tires, and an offroad tuned suspension, and modifications are needed to really be a great speed car. Limitless is great, but needing electronics bakes it not great for new RC folks.Onroad ... speed run ... first RC car ...
Veteran speed runners will tell you the Futaba 3PV is the one to get. I have one and range is more than I need so far. My speed runs are only about 75-100M away from me at any point so far. Haven’t had a single loss of radio yet. I’m using the R304SB-E receiver that doesn’t have an external antenna too. If I do end up running short on range later, I have the original R304SB with the external antenna too.I am sorry ...
I'm running a Typhon 6S v3 with Tactic TTX300. I'm searching for an RC remote control with a higher range for speed runs. Sorry for my inaccurate first question ...
This ^Veteran speed runners will tell you the Futaba 3PV is the one to get. I have one and range is more than I need so far. My speed runs are only about 75-100M away from me at any point so far. Haven’t had a single loss of radio yet. I’m using the R304SB-E receiver that doesn’t have an external antenna too. If I do end up running short on range later, I have the original R304SB with the external antenna too.
Wow. Is it that good?? I just picked up a dx5r. Maybe sell that to get the futty?This ^
Futaba has/had the farthest range of any other surface transmitter, I can't remember the exact distance but they had to communicate via cell phone as the driver could no longer see the car, I also remember it being significantly farther than the other systems they tested.
I'm contemplating ditching the DX5C and getting a 3PV instead.
Found it sort of old https://www.bigsquidrc.com/2-4-ghz-radio-transmitter-shootout/Wow. Is it that good?? I just picked up a dx5r. Maybe sell that to get the futty?
1Futaba 4PKS1233 feet
2Futaba 3PL1058 feet
3Traxxas TQ 2.4 with Link840 feet
4Tactic TTX-240808 feet
5Spektrum DX3S620 feet
