18V max input is pretty low and that's why you need such a high current to get 800W output. D6+ for example accepts up to 30V DC and therefore only needs about 22A + losses due to <100% efficiency (I have read 90% power efficiency for DC-DC converters at these loads, which would be about 24A input, but 60W waste power, seems too high/underestimating efficiency, charger doesn't get that hot and the fan doesn't run that much) to reach its peak output of 650W.
I think you can get away with less than 60A supplied to that charger, though. Assuming 100% input-output efficiency, at the maximum input voltage of 18V you'll need 45A. At 90% efficiency, you'll need 49A.
