so I looked at my chassis and it has a twist in it since I wrecked. I also had 2 screws pull through. Has anyone done a chassis swap with a dex8t? I have one on its way and was just wondering what I was in for.
Thanks
Thanks
Your going to need alot of parts, center diff mount, motor mount , and some others.so I looked at my chassis and it has a twist in it since I wrecked. I also had 2 screws pull through. Has anyone done a chassis swap with a dex8t? I have one on its way and was just wondering what I was in for.
Thanks
The center diff of dex8t is mounted to a plate then chassis. It looks like the mount holes are the same even with the different design. I know the gear cases are already the same, already have a dex8t gear case bolted to talion frame. The drive shafts can be used in either car. The chassis should be to me in next 48hrs. I'll let you know.Your going to need alot of parts, center diff mount, motor mount , and some others.
nice try man. lucky you saved me time from trying to do the same lolAfter careful consideration and the dex8t now being dead. I’ve decided to just build a completely new chassis
Rough cutout done
Also in hindsight I should of just ordered carbon fiber to make the chassis and made an aluminum plate around the weaker areas. Would have solved the weight issue and been close to indestructible. Hope this info helps everyone who is looking to go down this rabbit hole. LOLAnything happen with the new chassis? And did you get to bolt on the durango shock towers to the stock talion boxes?
