jlatimore3
- BigRock 4x4
- Granite
- Kraton 6s
- Typhon 3s
Hey guys, got a Kraton v5 and I've bent my rear shock tower. Looking to upgrade both. Are the ExB parts as tough as M2C or Voltage?
M2C uses 7076? IDNK.Hard to find a true objective comparison, they are all better than stock by far.
They will all break if doodoo happens but that is a very high threshold.
You want 7076 alu, I use M2C towers and not regretting the few $ extra and the sneaking suspicion that they are still better than EXB.
Voltage site is down, can't compare. I do use Voltage hobbies hinge pin holders in the back and they are great.
The EXB parts are stamped first, then CNC’d to remove excess material. They aren’t completely cut from a forged piece of 7075.M2C are renown for making the thickest, stoutest parts of the best 7075 grade aluminium. They're a massive 9.5mm at the thickest parts of the tower (I think they're 5mm at the narrower fixing areas)
Voltage Hobbies shock towers are also 7075 and up to 6mm thick and 5mm at the fixing areas, from what I've read
EXB 7075 towers are just 5mm all round. Apparently people have bent the chassis and has led to the belief that they're all a lower grade of 7075. I wasn't aware that they're stamped; they're all titled CNC on the Arrma website? @SrC
I've not had experience with any except the EXB ones my Mojave came with, but M2C would be my choice if it was me
^^^ This.If I'm paying full retail, m2c without question. If I'm getting EXB parts at a discount from a kit breaker then I'll consider the use case. I'm not a huge basher so for the most part, EXB parts work for me. For example, ~$45 for a EXB 7075 chassis might be worth it versus ~$115 for an m2c chassis. But your specific driving/bashing style should dictate your decisions.
Are you a weight weenie???Exb are lighter if that means anything. That is my only complaint about all the m2c upgrades, handling turns to , car is slower and electrics hotter. The m2c speed chassis are intriguing and may be a nice compromise along with some nice carbon towers for a lightweight speed basher.
Not particularly, but do notice the lighter talion I built can be more enjoyable and break less than my heavier Kraton.Are you a weight weenie???
You do have a good point however
M2C all the way. The shock towers are the same for Kraton and Notorious.Hey guys, got a Kraton v5 and I've bent my rear shock tower. Looking to upgrade both. Are the ExB parts as tough as M2C or Voltage?
I have an m2c'd out talion and it is heavy but still runs strong, but i max6/hobbystar 4092 all of my rigs. I am building a lightweight one now with a m2c speed chassis and carbon fiber where i can from basherqueen. I'm waiting on my crcu hinge pin blocks to come in and to send the shock bodies and aluminum braces/servo mount to be anodized black. The stock talion with hot racing hinge pin blocks and a 40mm fan on the motor weigh in at about 9.5 pounds by the way, so we'll see what one weighs with the lightened parts on it. I am throwing a max6/hobbystar 4092 on it as well so it may end up weighing more or about the same hahahahaha. If i think about it after work i'll weigh the m2c'd rig and see what it weighs. i do run it on 4s outcast tires too so there is a little more weight there.Exb are lighter if that means anything. That is my only complaint about all the m2c upgrades, handling turns to , car is slower and electrics hotter. The m2c speed chassis are intriguing and may be a nice compromise along with some nice carbon towers for a lightweight speed basher.
I did get my voltage center braces this week so it took about a week even with the crapshoot of the usps system.My Kraton has M2C towers, chassis braces, rear tower braces, and M4 shock mounts. That thing is a tank. Jumps that snapped shcok mounts and bent towers it just yawns at.
EXB is good stuff if the price is better for you. Tougher aluminum, but it's not beefed up designs like M2C.
Voltage seems to have ok designs and material, but they've been plagued by bad shipping times according to people on this forum. Evidently it's supposed to be improving, but I'd prefer M2C for the quality or EXB for the price.
