Typhon First speed run attempt! Typhon 3S
Yas
UK
Notorious, Outcast 6s, Typhon 3s
First ever speed run attempt and I was pretty stunned with the results 😳
20t 0.8 MOD pinion, 4000kv Maverick motor and Duratrax Bandito tyres all hooked up to a DX5C
Yonic
ArrmaForum Fan
Tel Aviv, Israel
Senton, Talion, Typhon 6s, Typhon 3s, Voltage
Nice!
Funnily, 2 days ago i had a similar run, same pinion and tires, only 3100kv motor and 4s. exact same speed :).
These tires are borderline controllable at this speed.
Yas
UK
Nice!
I was expecting 60 at most 😲 I hit 62mph after the first few passes so I kept at it... I kept getting voltage sags and then hit early LVC with a 6500mah 100c Gaoneng 3s though 🤔 stock motor with the 20t will be going back in for bashing later
jondilly1974
Speed running apprentice, 3D printing fool
ArrmaForum Fan
Toledo, OH
Granite, Kraton 6s, Typhon 6s, Typhon 3s
Yeah I tried those tires a few times and gave up. GRPs are just way more stable and have a ton more grip. The GRP are shorter so you will have to gear up to make up the difference.
  • Like
Reactions: Yas
Yas
UK
That reminded me to check the tyres... half of one of them had pulled away at the rim 😂 probably not rated this
GMballistic
ROSSA ~ Officially fast.
South Wales, UK
Limitless, Typhon 6s
Create account
Log in
