Anthony jaques
Ok so im a fab of both arrma and corrally I'm doing maintenance on my skeeter today which gave me an opportunity to answer a question I've had and thought I'd share 6s blx diff 31 mm corally 6s diff 35 mm but the line up perfect and corally aluminum diff is built identical to arrmas newer aluminum diffs no tombstones the pic is of them side by side and arrma rear diff in the skeeter obviously crown and bevel would need to match but bearing seat is on point and honestly corallys diff are impressive imho now I want to see if the corally fits inside the housing of arrma anywY thought I'd share
I think the arms are intractable oh snap I got an idea the 6s krally krato arms hubswould widen like 2 inchesOk so im a fab of both arrma and corrally I'm doing maintenance on my skeeter today which gave me an opportunity to answer a question I've had and thought I'd share 6s blx diff 31 mm corally 6s diff 35 mm but the line up perfect and corally aluminum diff is built identical to arrmas newer aluminum diffs no tombstones the pic is of them side by side and arrma rear diff in the skeeter obviously crown and bevel would need to match but bearing seat is on point and honestly corallys diff are impressive imho now I want to see if the corally fits inside the housing of arrma anywY thought I'd share
Oh the kraeterOk so im a fab of both arrma and corrally I'm doing maintenance on my skeeter today which gave me an opportunity to answer a question I've had and thought I'd share 6s blx diff 31 mm corally 6s diff 35 mm but the line up perfect and corally aluminum diff is built identical to arrmas newer aluminum diffs no tombstones the pic is of them side by side and arrma rear diff in the skeeter obviously crown and bevel would need to match but bearing seat is on point and honestly corallys diff are impressive imho now I want to see if the corally fits inside the housing of arrma anywY thought I'd share
