- Maryland
- BigRock 4x4
- Felony
- Granite
- Infraction
- Kraton 8S
- Kraton 6s
- Kraton EXB
- Outcast 6s
- Typhon 6s
Hope they didn’t discontinue them.
Guys horizon hobby has them! I was gonna order but thankfully my lhs has them in stock!Local hobby shop says they’ll have some in stock next week. We’ll see??
Horizon hobby has them. Online. ??I don’t seem them either
Ussualy on ebayAnyone know where to find these hot racing shock bodies anymore? I just ordered a set for my BR3S a month ago and now I can’t find them anywhere online. I want another set for the granite I’m building, but they’re out of stock everywhere.
Hey aimless and others who are running these...Still no leaks? I'm trying to decide between these HR bodies (45$) or should I go with the 6s typhon shocks? (70$) any advice guys?After a few packs, they are awesome!
No leaks and super consistent performance. Very easy to dial in your ride height and make quick adjustments.
No complaints so far!
If you don't care having metal stuff on your oil and doesn't affect the performance get the hot raving shocks idk if they have the same problem as the 4s shocks they make. So i cant really tell you thatHorizon hobby has them. Online. ??
Hey thanks for the reply! Funny you replied as I was just reading your thread on your 4s HR shocks. Its funny cause aimless and a couple others seem to be really happy with the 3s ones. Maybe there is a little difference between the 3s and 4s bodies although that would seem odd in terms of build quality. Maybe I should just pony up the extra 30$ and get the big bore 6s shocks....Personally i bought the hot racing shocks and i was not satisfied i had silver paint oil coming out when i bleed the shock flsuhed the dsm thing 5-6 times and i had enough even with a remplacement same thing idk what the fk is up with them. I got the typhon shocks and they are smooth like idk how to describe it lol you can buy actual spare parts for them thi the hot racing does not. I used the stock 4s springs rear and front the rear is a little bit stiff but thats what i wanted and the front is smooth like butter
But my brain would not accept to have metal in my oil specially on an hot racing r a fee check ups on my typhon shocks the oil is still clear like new and when i bleed the oil is actually completly clear
For the air in the shock i understood its always to have some degree of air inside no matter what you do but the thing with the hot racing one is that the piston hits the top of the shock and thats where the air bubbles are so when it compresses the air is going trought yout whole shstem but on the typhon shocks there is like7-10mm of clearences meaning tha the shock shaft when fully compressed doesn't hit the shock bladder at all and the air never start to cycle arround you shock but stay in the top and keep the smooth action to lastHey thanks for the reply! Funny you replied as I was just reading your thread on your 4s HR shocks. Its funny cause aimless and a couple others seem to be really happy with the 3s ones. Maybe there is a little difference between the 3s and 4s bodies although that would seem odd in terms of build quality. Maybe I should just pony up the extra 30$ and get the big bore 6s shocks....
Yeah I hear you. Plus i don't have to take apart and build 4 shocks which will save time. Thanks all you guys for your advice! I think I'll go with the 6s shocks. Plus I love my typhon so worth the investment. It's one of my favorite trucks for sure! Although I'm kinda regretting not just going with the 6s model at 170$ more and after buying the shocks for 70$ it's only 100$ more.Nope, no difference from the 3s to 4s line bodies besides the overall size.. manufactured the same way.. they have been great for me.. no issues at all.. but you may as well grab the 6s shocks, because the cost of stock shock shafts will bite you in the end anyway.. the 6s shocks are ok, they aren't spectacular by any means, but they will serve you well, with way less leaking, sloppy shafts and all..
They work as good as the person who assembled them its not hard with the bleeder screw position. The only problem I have is that they are shorter than your stock and my tires are grounded at all timesIf they are as good as their metal driveshafts, RUN AWAY AS FAST AS YOU CAN. Honestly, I really don't like any of the HR aftermarket for the 3S line. Even the 17mm hubs have issues and the alloy for their stuff is as strong as straw.
Yea of course, is there is another way?I am still using the bottom half of my stock
That’s not a piston it’s a cap that goes on the inside of the bottom of the shock.Eeeeenteresting. So, you keep the shock shaft and the lower mount/spring perch. The picture seems to have a new piston and some shaft seals as well. I can't tell for sure, but it almost looks like the pistons aren't pre-drilled with any holes. Color me curious.
Go to hot racing’s Facebook page they have instructions on there and I think some videosHello everybody
I'm new to the hobby and forum.2 days ago I received the hot racing shock bodies and I am waiting to buy shock oil to install them. What oil do you recommend to buy? AimlessRC you are going to upload some video of the assembly? That would help me a lot.
Thanks and regards
YesYea of course, is there is another way?
are we talking about the same thing? hot racing shock bodies for the 3s cars?
Then I’m not sure what’s the difference is. Mine are longer than stock
Where did you get the blue gray stuff at?Just the blue good stuff grease...
