Hi guys! I just bought a set of stainless steel sealed bearings from jims
I just wanted to know how long they typically last
thanks!
thanks!
After how many packs would recommend doing maintenance?Years with regular maintenance. Sealed bearings still require maintenance. Remove the seals clean the bearing and repack. I do mine a couple times a year depending on use.
What grease/oils do you use ? I just wanna bash aroundAll depends on how you run. Someone playing in the mud has to do it more often then someone who stays on road. I pull center diff out and spin everything by hand to make sure is feels and sounds good. You will know when one is bad.
Can you remove the seals on, say, some Fast Eddies?Years with regular maintenance. Sealed bearings still require maintenance. Remove the seals clean the bearing and repack. I do mine a couple times a year depending on use.
