- TENNESSEEESSEEEEEE
- Limitless
- Mojave
- Typhon 6s
I can tell you didn't read the thread.
Everything is working just fine so we already know it wasn't the PP module. I only just today offered up why I started the thread in the first place because in the OP there's no mention of what problem I was having (or if I was having a problem at all). I was just looking for someone with this setup for a chat.
That's not how any of this read to me. I guess your intentions went over my head.
I understood the problem to be that you had a problem with the PP module's throttle delay and couldn't figure it out.
"the ramp time from when I pull the trigger to max RPM is about 4 seconds and not the 8-9 seconds I was expecting."
"I figured it would be quicker to just set up a new model profile with everything reset to default. I did that and still, same problem."
"Now I'm beginning to scrape the bottom of what I "know". I started to consider if the PP module I got was possibly defective but before I assume anything, I decided to compare my config to Raz's and check for differences. The only thing that really stood out was the receiver. I'm using the 334SBS and Raz is using the same one he uses in every video (at least I can't remember him ever using anything else), the R2006GS aircraft receiver. Nowhere is there any mention of Rx constraints in any of his videos and I'm really confident that Raz would have mentioned this in his videos if there were an issue with the standard issue receivers that come with Futaba transmitters. That would be a really big deal if a particular receiver was necessary for the PP module to work so I discarded the Rx as the culprit."
Everything I read in there sounds like you are investigating why the PP module is not working as expected.
