Thanks!
ImEV Peak and HTRC have both been around for while now and are both good brands. I just went on Amazon searched for lipo balance charger, sorted by customer rating and the HTRC charger was the 3rd listing, the Skyrc is 16 if that matters. ?
Thanks! I’ll definitely look into thatHeres a screw kit which also has the cross wrenches. its for a v5 but I would think most of the hardware is the same...you might also want to buy a set of wheel nuts, if you loose one its game over. https://jennysrc.com/collections/no...screws-tools-hardware-nuts-t-wrench-ara8608v5
I bought one of those as my first charger, it was one of the Thunder rebrands so mine was black. It works pretty good. I have a Hitec X2 400 now and it exceeds my needs.This is a budget charger that performs. I still have mine after many years. Works perfectly for your size lipos. The price is right IMO. And it will storage charger your Lipos nicely. Important to do to your lipos after use!
I also have better $150+ dual chargers but you don't need them.
Amazon.com: SKYRC B6 AC V2 50W LiPo LiFe LiIon NiMH NiCd Battery Charger Discharger: Toys & Games
And you need this charger cable for your Lipos. along with the above charger.
(XT90 connector)Amazon.com: Apex RC Products XT90 Connector Plug -> 4mm Banana Plugs Battery Charge Lead Adapter Cable - 2 Pack 1416: Toys & Games
Others may chime in with many other lipo chargers out there.
Oh nice I was looking at that same charger cause someone else mentioned it was pretty good. I also saw a guy selling a spektrum s1200 for $45. Is that a better charger ? And any difference between that sky rc b6. And the b6 mini?This is a budget charger that performs. I still have mine after many years. Works perfectly for your size lipos. The price is right IMO. And it will "Storage Charge" your Lipos nicely. Important to do to your lipos after use!
The S1200 is DC only so you would need an external PSU something 250-300w.Oh nice I was looking at that same charger cause someone else mentioned it was pretty good. I also saw a guy selling a spektrum s1200 for $45. Is that a better charger ?
I might get one of those skyrc b6. Would it charge 6s also? Is it one battery at a time? Any idea how long it takes to fully charge a battery? Also any differences between the b6 and b6 mini?
Yes it "can" charge a 6s lipo but it will take a long time, unless the lipo is around 1000mah. 1 battery at a time.I might get one of those skyrc b6. Would it charge 6s also? Is it one battery at a time? Any idea how long it takes to fully charge a battery? Also any differences between the b6 and b6 mini?
Charger Wattage Requirement |
126 Watts (W) required as an output from your charger. |
148 Watts (W) required from your power supply. |
5 Amps (A) charge rate required of the charger per pack. |
It would take approximately 65 Minutes to charge 1 pack(s) from less than 20% capacity. |
168 Watts (W) required as an output from your charger. |
198 Watts (W) required from your power supply. |
It would take approximately 65 Minutes to charge 2 pack(s) from less than 20% capacity. |
https://www.radiocontrolinfo.com/information/rc-calculators/rc-charger-wattage-calculator/#B
Charger Rate Per Pack(C) Charge Current Per Pack (A) 0.51 C 2.55 Amps (A)
The batteries that came with the car assuming they are 4s will take approximately 127 minutes to charge depending on a few different factors. The max charge rate calculated above will occur near the end of the charging cycle when the battery pack ramps up to maximum voltage. While the voltage is ramping up to maximum voltage, the charging rate will be slightly higher as max voltage has not yet been achieved.
Don't get the mini, it doesn't get as good of reviews as the regular B6.
Just to toss this out there this is for a 6s 5000mah lipo.
Charger Wattage Requirement 126 Watts (W) required as an output from your charger. 148 Watts (W) required from your power supply. 5 Amps (A) charge rate required of the charger per pack. It would take approximately 65 Minutes to charge 1 pack(s) from less than 20% capacity.
Oh ok. Why would the 4sYes it "can" charge a 6s lipo but it will take a long time, unless the lipo is around 1000mah. 1 battery at a time.
oh ok. That’s not bad. Might go with that. I don’t think there’s something better then thang for under $75Yes it "can" charge a 6s lipo but it will take a long time, unless the lipo is around 1000mah. 1 battery at a time.
-edit- Now that I look at the wattage calculator and again assuming the lipos are 4s I wouldn't get the B6AC, you are maxing out that little guy for 2 hours charging 1 battery. You have 2 batteries so at the very least you are looking at 4 hours of charging.
-edit2- This is what you would need to charge both batteries at the same time. Basically you would want a 200w dual channel charger.
Charger Wattage Requirement 168 Watts (W) required as an output from your charger. 198 Watts (W) required from your power supply. 5 Amps (A) charge rate required of the charger per pack. It would take approximately 65 Minutes to charge 2 pack(s) from less than 20% capacity.
Nothing AC that I can think of off the top of my head.Oh ok. Why would the 4s
With 4s lipos?When looking at chargers. You need an AC version . Whatever you choose. The DC chargers runs off of 12 volts only. They appear cheaper for this reason. Be careful when looking. You will get dizzy seeing all that there is. The Spektrum S1200 is over rated and it is not AC.
The B6AC charges my batteries within 40 min when lipos are at 3.8 volts. I think that's fast enough for the OP's pricepoint. I could be wrong.
Thanks for info. I did end up buying it.Buying used is tricky. I bought my Senton from a guy 3 hours away, and gave it a test drive in a gas station parking lot. 98% of the damage (scuffs etc)was caused by me, meaning it was MINT when I got it. The guy was a RCer so knew how to look after it. He should have taught me lol. Price was fair in my opinion as I didnt want to buy new and grow bored with the hobby.
My advice? Pay attention to what everyone is telling you. Ask how it should etc. One thing I learned in my short time enjoying this hobby is damage is easy to hide and quick fixes are common. Personally I think its a bonus the guy is local to you.
Ask him to test batteries in front of you. My guy threw in 2 2s 5000mah Gens just so I could have something to run on until I got my own 3s batteries. And hooked them to his portable charger/tester to show me they were more than decent(I know now but had to take him at his word then)
Yeah I’m trying to stay under $100 for a charger atm. I mean is it pushing it to hard on that b6 to be charging 6s down the road?I can also suggest a Hobbymate D6 Duo Pro (200Watts with AC) $159. And a this charger will provide 650watts if he spends another $100. on a separate 24 DC 650 watt Power supply. This will 2 6s batteries real fast .?
I don't know that he would want to spend that much. At least right now.
I never stressed out with charging on my Sky Rc B6AC v2. Sure it took longer slightly. But when the lipos are at 3.8v they don't take longer than hour.?
@ALex38 said he wanted to stay under $75.I can also suggest a Hobbymate D6 Duo Pro (200Watts with AC) $159. And a this charger will provide 650watts if he spends another $100. on a separate 24 DC 650 watt Power supply. This will 2 6s batteries real fast .?
Nice. Those would charge faster since it’s 150w. But I’m guessing the skyrc is proven and tested. Not so much these ?@ALex38 said he wanted to stay under $75.
I have been looking around on Amazon and found these 2 options under $75
https://www.amazon.com/EVPEAK-Input-Balance-Charger-Batteries/dp/B01D4D059K/ref=sr_1_44?dchild=1&keywords=Lipo+Balance+Charger&qid=1608094752&refinements=p_85:2470955011&rnid=2470954011&rps=1&sr=8-44
https://www.amazon.com/Charger-Battery-Balance-Discharger-Adapter/dp/B07R18YNZQ/ref=sr_1_3?dchild=1&keywords=Lipo+Balance+Charger&qid=1608094752&refinements=p_85:2470955011&rnid=2470954011&rps=1&sr=8-3
I would lean more towards the HTRC over the EV Peak just because it has a little more wattage.
EV Peak and HTRC have both been around for while now and are both good brands. I just went on Amazon searched for lipo balance charger, sorted by customer rating and the HTRC charger was the 3rd listing, the Skyrc is 16 if that matters. ?Nice. Those would charge faster since it’s 150w. But I’m guessing the skyrc is proven and tested. Not so much these ?
I should have linked to this thread a long time ago lol@ALex38, You have some research to do. Its your call, your wallet. I can tell you what I have. Others also. All chargers do the same, they charge. You need an AC charger , so you can charge from the house without the need for a car battery or separate $power supply$. That's all. Price you pay determines how fast it will charge and how many it will charge at a time. The more Amps and watts the charger has to speed up charging the more money it will cost. That is your criteria. Good luck researching.
