Kraton Kraton 6s build
Sandracer_NL
Hospitality Award
Netherlands
  1. Fireteam
  3. Mojave EXB
Got my K6 Friday (actually my first Arrma ?).
What I’ve planned (so far, but can change daily ?)
- RPM front bumper
- Strengthen body with drywall tape and rubber seal
- Leds (ordered new ones since I never got the ones I ordered 10 weeks ago ?)
- Yeah racing heatsink dual fans
- Replace dual fans with Rocket fans
- Aluminium Rocket fan covers
- Wheel hubs (closed serrated hubs)
- Replace all bearings including steering bushings.
- Ceramic bearings for motor
- Murat RC rear mud guards Ordered MLine as well and will use those on the K6. Will try to fit the Murat’s on the buggy.
- Mline center and rear mud guards
- Change the look of the rear wing
- Currently looking at Louise MC cross tires (belted). Like them a lot but not 100% sure yet since teach tire weighs 140gram more than stock ?, which adds quite some weight in total. Decided to keep the CHeads2
- White lettering on tires Done, and logo red, bolts silver on rims.
- Probably EXB chassis braces (sold out?) Was thinking about these since I wanted them to be red. @jondilly1974 made me change mind my again and ordered GPM?
Most of the things are ordered, so only done one thing on the list, which is the rear wing look. But doesn’t matter, because I‘m very happy how the wing turned out!?
Another couple hours later...
Think I will be using these side mud guards; although they don’t have the ’fin’ the ones have that are fitted now, these are a wider cover the complete arm. So they protect the rear hubs instead of the turnbuckles.
Also received replacement receiver/transmitter and stronger servo today, and shock socks?.
Working on the body.
Feels more solid than the stock ‘flimsy’ feel.
With the belted tires weight is starting to add up, so took the kitchen scale.
Body 322g
Wheels 1.708g
’Chassis’ 3.785g
4s lipo 590g
subtotal 6.405g
leds,wheel nuts
Total weight 6,5KG (14lb 5oz). So I added around 1KG ( 2lb 3oz).
Even though it’s only 4s and I don’t do WOT all the timeI‘m having second thoughts whether I should change the 16T and go lower.:unsure:
Installed roof protectors and started with some lights.
Not sure whether to go for the normal angel eyes style or to make them more agressive (more BMW style) ?
Leaning towards the BMW style, but depends with the look/visibility when I install the other lights (fog/search lights).
Got LEDs yesterday, the 4 red ones in the rear are done. Was about to work on 4 ones for the front when the postman just delivered 3 control switches (for the LEDs) and the aluminium servo mount?
A few more things are on its way than I think I’m done building (for now) ?. The K6 hasn’t even been driven yet ?, it’s about time. But working, drilling, glueing, on it while everything still is factory clean is better I guess.
