Not the best for rotation, but more stable.
Running 6s, haven't hard courage for 8s yet lolYou running 6s or 8s??
LP's work for me in the loose compared to the 6s BF's. Ran them just one pack on loose clay. Baseball infield. On 6s.
Lp's seem better for more technical driving. I feel the standard 3.8 Badlands ( not the MX's), similar in diameter to the Lp's, are gripper though. Softer rubber and foams with the PL Badlands. Both types of BF treads are a copied design from the Badlands. FWIW.
Just my thoughts. Others may have a different experience.
For people that have run both, do the LP tires struggle more in thicker grass? My outcast 6s on backflip MT tires does better than my kraton 4s on minokawa LPs. I’m not sure if it is a wheel diameter issue, or if the minokawa LPs are just spinning in the grass.
Outcast 4s. You can find the wheels by searching dboots backflip lp.Which arrma rc has the lp's stock? A link maybe?
Minokawa’s are junk put a set of lp’s on that 4s kraton and it will come alive. Better yet I love the 6’s katars on my 4sFor people that have run both, do the LP tires struggle more in thicker grass? My outcast 6s on backflip MT tires does better than my kraton 4s on minokawa LPs. I’m not sure if it is a wheel diameter issue, or if the minokawa LPs are just spinning in the grass.
1/2 offset. I know what you mean.Running 6s, haven't hard courage for 8s yet lol
I do have a set of proline badlands (none Mx) 3.8s but have a 1/2 offset. I set them on and they seem WAY wider than stock copperheads. What offset is typical for kraton using badlands 3.8?
Even tho I have the proline badlands I didn't like the look of them on the kraton, really wide and smaller than the other options. Plus I use those for my JLB Cheetah. Ended up buying BF MTs instead of LPs (drinking was involved) haha but good news is got it from Amazon and if I don't like them I can return it may end up keeping them and just buying the LPs and use the LPs for racing with my buddies and the MTs for hard bashing. Won't be able to run it this weekend being valentines day and all, unless I dare leave the wife to go play on valentines day, I would come home to an empty house! Lol1/2 offset. I know what you mean.
BTW, I hated my Copperhead 2's. I never use them. Prefer anything over them. Makes the rig so clumsy and drives awkward. But I generally like DTX X-Con Zero offset Truggy track mini pins most of the time. Even 1/2 ofset X-Cons drive better, just a wider track. depends Where I bash. How I drive. I like my Kraton to drive more like a 1/8 scale Truggy with narrower track.
