You can put them on anything. I just thought it was cool that Hobbywing included that into Their ESC... this way you can use non anti sparks with it.
Oh yeah, most definitely!
Hey Vanning and Kauaiguy, need your input please. First off, I am ridiculously happy with my Leopard 4092. No more mombas for me. I want to make sure I'm running safe temps. Running on 5s for 15 minutes with 17 pinion, motor temp 151, battery temp 91, ambient outdoor temp is 68, ESC temp 123. Acceleration is excellent, top speed is equivalent to or better than my Momba in my Talion.
I hit 185 on my 1480kv with 17/46 gearing doing short full throttle bursts, does that sound about right to you Vanning?I've hit 200 plus with mine because I had a bad connector solder joint. It's still working fine. I didn't hit it for too long because my ESC shut down. 164F, that's not an issue. I like to try and stay lower because my Kraton runs for a long time on a charge. Part of that is due to running cooler.
Same as 21/50, maybe I should be checking soldering alsoNope. Sounds hot ??? Isn't that very slow mph gearing ? Should be rather cool with that gearing. Sounds about right for a bad solder joint. Or it doesn't like to be under geared.
21/50 is 2.38 and 17/46 is 2.70 to 1. How is that the same Gear ratio ? 21/50 will get the heat up.... I run 19/50 or 20/50. I can stay pretty low with that. 20/46 is close to 21/50. Yeah..... my rig didn't do well on the Castle connectors. I should have used a torch to put them on I guess. My temps sky rocketed with them on. I never had issues like that in 30 years of rc. I cleaned up everything and redid the solder. Runs fine now.Same as 21/50, maybe I should be checking soldering also
Oops my maths was wrong. I will go back to 15/46, didn't have issues then.21/50 is 2.38 and 17/46 is 2.70 to 1. How is that the same Gear ratio ? 21/50 will get the heat up.... I run 19/50 or 20/50. I can stay pretty low with that. 20/46 is close to 21/50. Yeah..... my rig didn't do well on the Castle connectors. I should have used a torch to put them on I guess. My temps sky rocketed with them on. I never had issues like that in 30 years of rc. I cleaned up everything and redid the solder. Runs fine now.
Okay, got my 4092 ordered! What size motor connectors does this have? 4mm? I couldn't find that anywhere. Thanks!
Hey man what gearing are you running in your kraton? I saw you were running 18 tooth is that with a 50 spur?Only run 6s with my 4092. No problems
Looking for gearing I have that motor on the way.. I run src road crusher and dboots backflip tiresHey man what gearing are you running in your kraton? I saw you were running 18 tooth is that with a 50 spur?
I run 17/50 gearing with truggy size tires. My 4092mm motor is 1480kv
