Limitless Limitless 8s spektrum
Chillicothe Missouri
  1. Infraction
  2. Limitless
  3. Kraton EXB
  4. Senton 3s
Hey guys I don't see a lot of people using the spektrum stuff so I figured I'd chim in and let you know the results I got. Car is as follows.
-Stock limitless roller.
-8s outcast electronics with 1250kv motor.
-34 spool 34 pinion.
-Infraction receiver box and esc cage, fits the esc perfect and you can use factory hardware.
-Stock remote and receiver from Infraction.
-Spektrum 4s 100c smart batteries.
Hit 108 on fresh packs, not sure on total distance. Could probably hit 115 on a longer stretch of road.
Motor temp was 119 after 3 back to back passes. When I had the gearing at 30/34 103 was top speed.
Anyways just figured I'd let you know what my end result was so far after testing the spektrum smart system. I will be shutting off the lvc, with 34/34 the batteries can't take more than 3 passes. Before it falls on its face at 95mph
Thanks for the info.
I’m currently at 99mph on 8S with 1250kv motor in an Infraction with 27/34 gearing
And 113mph using a 2050kv Spektrum motor on 8S with 27/39 gearing.
I’m hoping to reach 130mph but I need 2000 feet of good road.
