- Rhode island
- BigRock 4x4
- Kraton 6s
- Outcast 6s
- Vendetta
- Infraction 4x4
- Thread starter
- #21
Ok .advice taken .since speed passes is all I do then I'll save my loot for the futaba gyc...thank youwell FWIW,
the GC301 and pretty much all gyros will work with any transmitter and receiver combo. I'm using a futaba radio myself. That being said,
I do not believe any of these servos (other than the GYC futabas) will have any significant advantage for speed running. These gyros are designed to correct/mititage an oversteer condition (which pretty much never occurs in speed running). If anything, if the sensitivity is set too high, then the wheels will oscillate/twitch at high speeds increasing the risk of a crash.
AFAIK, futabas are the only ones that have a setting to keep the car straight (I could be wrong so do you own DD). So if the application is for speed running, save your money and buy a futaba GYC or don't buy it at all. For bashing and oversteer correction, they're all pretty much the same and for drifting, I am told the futaba GYD series are the ones to get.
So back to my question on my transmitter.should I be using it instead of the stock firma? I mean can't hurt since the flysky GT5 is alot better. but I heard the distance you get from these stock firma transmitter are better than most transmitters being sold..what should I do?
