Looks like your ESC cable got stuck in your spur, normally loud noises are diff related.hi everyone. I’ve been having problems it sounds real loud sometimes and loses power. Then I noticed this. Plus another cut down the wire. Could this mean new ESC
Yea it did just unsure with that little wire coming off. In the past when I’ve had this blue wire Come off the motor it’s doing a similar thing to that. So confusing I’ve had all 3 diffs off and there fineLooks like your ESC cable got stuck in your spur, normally loud noises are diff related.
The little wire only matters if you are using smart battery’s and using telemetry stuff, does not effect performance of the ESC or motor.Yea it did just unsure with that little wire coming off. In the past when I’ve had this blue wire Come off the motor it’s doing a similar thing to that. So confusing I’ve had all 3 diffs off and there fine
ThanksThe little wire only matters if you are using smart battery’s and using telemetry stuff, does not effect performance of the ESC or motor.
I’ve been there before with the esc wires. Now I keep them zip tied. The loud noise is that a clicking sound under power or braking?
How is your gear mesh? Sounds like it may be too loose? Otherwise center diff related imoThanks
Done this videos to show you when it’s not got weight on it or I drive slowly it’s fine but soon as I give it some it does this clicking noise. As you can see in this vid front wheels don’t even spin when I put a little bit of weight on it. And it sounds awful Yesterday I had all 3 diffs off and they was all fine.
That video isn’t playing on mine hope it works for you
& no excessive wearing on either the pinion or spur gears? Or missing teeth on either?
It sounds well bad in this video.
Good call but Just checked that one unfortunately it isn’t the search goes onIs it possible, that your pinion is loose? I had this once and it sounded somewhat similar.
Also, try strapping down your battery cables under the velcro strip that goes over the width of the battery. That's what I do and it helps with cables flopping around and getting cought in something.
I’ve had all the diffs off barings are fineCould be as simple as a blown bearing inside the diff housing. Open up your front diff and see whats going on
ICould be as simple as a blown bearing inside the diff housing. Open up your front diff and see whats going on
