Evil Jim
Good day, all -
Given the paradigm shift in radio systems since the 80s, I have questions about certain aspects WRT installation.
First and foremost, what's the deal with the antenna(s)? I've seen all manner of placement within various machines...none, stubby, familiar (vaguely, but still shorter), doubles...and most of it is quite different from the old AM/FM days of, "Get as much wire outside the car as you can...and as high as possible!"
Does it matter at all? I can see where crawlers could probably care less (no meaningful rig/driver separation), while speed runners will want maximum range/signal, out on the tarmac and runways.
Second concern is keeping the Rx protected from water intrusion. I'm still getting used to seeing crawlers and bashers running through puddles and creeks, but it seems the Rx is rarely a listed waterproof component...unsurprisingly. For anything new, pretty much every kit/RTR comes with some sort of box, minus some race machines.
What about dropping a modern Rx into a gold tub, or similar...what would folks recommend? And as an added wrinkle to this, what if you've got a really small Rx form factor? I decided to go with a RadioLink RC8X and the lowest channel (4ch) option is a Mini-Z size, naked board style...and it's absolutely minuscule. I think the ESC/servo plugs will dwarf the poor thing...it's almost as much plugs, as it is anything else.
Which is great for fitting it into the buggy, but not so much for finding a decent box to put it in, in the car. Aside from all the boxes (all parts, really...always hated that part) being so ridiculously car-specific, not just in mounting, but overall shape/size, too.
At a minimum, I can pop the Rx into a balloon and zip-tie it to something.
But that's...pretty lame.
EJ
EJ
