Chris Lane
- Kraton 8S
Chicago is to far.., looked sweet. Your going to like the Kraton, I agree you want you bones flush. Congratulations on the RC and now we all know you aren't a troll... ????????Chicago area. It was a stool cart kit BUT it took lots of extra work. They always say its a fit together and drive kit but that's not how it worked. Had to get 2-1/2 inch aluminum stock, measure, cut, drill to fit under the 212 pred engine in there using the torque converter, grind and smooth out the bottom of the TC to clear the frame, ordered new bars, grips, doughnuts for the grips, throttle and cable, drilling new holes in brake brackets to make it work, MIG weld the front steering column, grind down, rust proof spray bed liner on welds ETC.. Just lots of the extra nonsense to make it work. Kinda like RC.. It's got 2-1/2 inch solid stainless steel shaft, will wheelie my 6-1 220lb butt down the road.
On to the 8S, took the rear end off, took the rear diff out, cleaned out all the bearings, added speed cream (you boarders know what that is) added my lightning grease to the ring and pinion, put back together. What a huge difference in the way it sounds spinning the gears after that! On to the rest of the bearings today. Diffs and fluids will come once I figure out what mill and ESC I'm going to install and depending on where/how its unloading after that.
I'm not in love with the ride height or re-bound either in 70 degree temps, I might pull the shocks off and experiment with different springs, oil and pistons once available. (EDIT: You must put your batteries in the truck before adjusting ride height) Spring pre-load all the way out is still too high for me. Might even drill an extra hole in the piston and go heavier oil depending on rebound/ride height. I'll be setting this up as close as I can to my old 1/8th Truggy set up sheets. Setting up for race tracks you want your bones flush with the ground or just a tad under. Bones are stronger flush and wont tear up your cups as fast. Will I be racing it? NO. Will I be bashing it and pulling/kicking huge rocks off jumps with it, most likely not. Just going to tear through grass I don't own. Balancing the wheels will get done too.. (I have a wheel balancer I used to balance the bar stool cart wheels) what a HUGE difference that made let me tell ya! My 10th and 1/8 balancer is WAY too small for 8S wheels..
