cazrack
XRT snowbash -1 celsius
20/46 Louise x uphill mft xmaxx tires
I probably need to think about the temps :-/
Traxxas 4s 6700 batteries
Sliding drifting speed run and lots of wheel spinning on nice snow and ice.
TSM at 75%
From manual intresting:
• Temperature LED ( ) Solid Red: The VXL-8s has entered Thermal Shutdown Protection, Stage 1 to guard against overheating caused by excessive current flow. The VXL-8s will limit the power output to 50% throttle. Stop driving the model. Inspect the cooling fan on the ESC to make sure it is operating. Allow the power system to cool before continuing.
• Temperature LED ( ) Fast Blinking Red: The VXL-8s has entered Thermal Shutdown Protection, Stage 2 and has automatically shut down (fail-safe mode). Stop driving the model. Inspect the cooling fan on the ESC to make sure it is operating. Allow the power system to cool before continuing. If you are experiencing frequent warnings about temperature, it could be caused by overgearing (from stock), overly aggressive and continuous high speed driving, vehicle damage, or driving in conditions such as deep sand, heavy mud, and tall grass.
When using higher gear ratios, it is important to monitor the temperatures of the battery, motor, and speed control. If the battery is extremely hot (150°F) and/or the motor is too hot to touch (200°F), your model is probably over-geared and drawing too much current. This temperature test assumes that the model is close to factory stock weight and operates freely with no excessive friction, dragging, or binding, and the battery is fully charged and in good condition. Note: If not using the pin system, check and adjust gear mesh if a spur and/or pinion gear is changed. This model is equipped with a Velineon 1200XL brushless motor. The gear combination that comes stock on each model provides good overall acceleration and top speed. If high-speed gearing is used, it is not recommended for off-road or repetitive starting and stopping. Temperatures and Cooling The XRT includes several features to help cool the electronic components: a motor temperature sensor, motor cooling fans, motor heat sink, and electronic speed control cooling fan.
The motor temperature sensor is factory installed and provides accurate telemetry data and thermal overload protection for the motor. If you remove the temperature sensor for vehicle maintenance, be certain to reinstall it correctly. The sensor should be installed so the thermistor (the small component at the top of the temperature sensor) is on the top of the motor (the side where the wires exit the motor). The sensor should also be centered on the motor. If the sensor is installed incorrectly, inaccurate or false readings will be sent to the speed control, and your model’s performance may be compromised. Do not operate the XRT without the temperature sensor. If the sensor is missing or incorrectly installed, overheating and permanent motor damage may occur. Damage caused by overheating is not covered by the limited warranty. The XRT also features factory installed cooling fins. These cooling fins help pull the heat away from the motor. Also, the electronic speed control features a cooling fan to assist in cooling the VXL-8s in high current motor applications.
Guess I was close to get it
200 degrees Fahrenheit =
93.3333333 degrees Celsius
