I do know you can get water cooled for rcs whether you can have watercooling on your rc depends on how creative you can be.Liquid cooling available?
I can get very creative. I come from racing drones and PC builds originally. Running 8s esc. 8s standard spectrum setup. Speed running and street bashing. Heats up faster trying to drift.
I'm thinking of trying to 3d print some intakes for esc and cut holes in body.
But that only really help while moving straight in theory. Not as much when going slower bashing around parking lot.
Mostly looking for ideas or if someone has already done it.
Saw one guy on YouTube totally change how everything was mounted but wasn't very elegant of a solution.
Arrma seems to waste alot of space under limitless body.
EDIT: I don't have a way to find temp but def too hot to touch.
Doing some maths here. Not removing space for servo, center brace and motor, there is 200 cubic inches of space under the hood.......
I don't think you want to add a water reservoir to your RC car having all that extra weight sloshing around potentially making the car unstable. On RC boats that are surrounded by a gigantic water reservoir that they don't need to haul around with them a water cooling system makes sense, but on a car? I concur with what @TL01magic said. Server fans is where it's at. Two 40mm fans even just running on 2S can move an impressive volume of air. On 3S they move sufficient amounts of air that they can easily levitate. I can recommend the website digikey.com. They're fast and they have a truly gigantic selection. I put two of these on a Powerhobby fan mount, added a 3-way switch so I can chose between off, 2S and F5 tornado.Spectrum 160 with 1250kv can.
Spur (stock)?29/34 pinion stock roller
Punch out @ 4
Want to keep setup as is how to cool esc better ? Not afraid to mod.
Thanks
04028DA-12T-AK-HAQ 12-04028DA-12T-AK-HAQ-ND 40MM X 40MM X 28MM, 12VDC, W 4-W |
..... the stuff about cooling the can still not cooling the important bits in the motor.
If a fan/heatsink is not enough, reducing the load(smaller pinion) is always the correct answer. An BL motor is not like a cpu. If it gets too hot for the application, you have to go bigger.Thanks for the tips I didn't consider the stuff about cooling the can still not cooling the important bits in the motor. I just got some fans from Amazon and a step up regulator to see if I can run them on the spectrum bec instead of another battery.
Was watching some videos about the cars aero and am going to do somethings. Anyone see any definitive data on cutting the front / rear wings down? Or cutting holes in body for venting? Not sure if get body is 100% requires for over 150mph runs
So got some real data on a speed run today.Cutting the front and rear is better for high speeds in terms of load. Yet with your current electronics, ~115mph will be your maximum speed.
Never go bashing with the car setup for top speed.
That's some really great input thank you. I haven't added any extra tuning on the suspension except droop to counteract the body roll and lifting of front tires. IA 89mph gearratio is not superfast in terms of speedrunning, but for bashing, especially with partially drained batteries (results in more amp draw), where you do not give the system any rest it will run hot quickly. Gear it down and you can...
Or upgrade the motor and esc. Both have a threshold of 4-5k Watts. Frequent bursting will heat things up even with half the wattage. A bigger motor and esc can deal with more whiles staying efficient (not generating excessive heat)
Spekrum does not measure temperature of the motor, the thermal/low voltage/ high amp protections all kick in based on what the ESC measures.
But ESC and motor are directly connected by 3 wires and will overflow excessive heat to each other. It can really help to put a high speed fan on both the esc and motor.
The vents are nicely done but will cause blowovers when you start doing 100+ speedruns.
The wear looks like you run a lot of camber (valid option) or just tire imperfection/balance that exposes the inner wall side to wear more during drifting
