You are getting close! Sounds like an offset would take care of it.All the 4 corners 0.30mm, in the middle somewhere between 0.25-.027
Looks like you are already headed there
Are steps of 0.05 good or smaller steps?Ok.. start another one of the bed leveling tests.. on your printer screen go to settings, scroll down to expert mode and click that... Then click, Z offset..
while the printer is printing, raise the bed and pay close attention to the layer lines.. as you get closer you will see them start to close up.. once you get them to close up you will be there...
Record the value on a piece of paper that it took to get them to close..
You may need this later
I started 0.05 bumped it up to -0.50 and -1.00 and must say the -1.00 lines look really good, now that you say make smaller steps. i wil go .0.25 up and down. by every step i am writing it down with the marker so we have some exact data to compare
This is an interesting thread. Why doesn't the auto bed level compensate for this? Manual adjustment still necessary..-01,00 looks absolutely the best. The lines are smooth and fused. It doest have some small defects ( don't know the correct term) as the -0,085
Agreed.. -1.00 looks best.. those spots you see are where it's a little to close.. deviations in the bed cause this..-01,00 looks absolutely the best. The lines are smooth and fused. It doest have some small defects ( don't know the correct term) as the -0,085
I would stick with the -1..
Its wonky at best... The main underlying issue is the mesh.. it doesn't probe enough points..
Is there a way to manually adjust >> increase the probing points??
Now you mention it, if i look at the bed level: the left side is higher, and the more it prints to the left the bigger the spots get. do i have to worry that the nozzle may scratch/ touch the bed? or are the chances zero?Agreed.. -1.00 looks best.. those spots you see are where it's a little to close.. deviations in the bed cause this..
