LtGhost08
Looking to pick up an outcast here shortly. What parts do you guys happen to keep on hand at all times? Id like to have some common parts on hand in my parts bin.
Recommend researching the cost of the rebuild kit vs one from JRC. You can probably get the whole assembly cheaper than a rebuild kit.I was thinking of getting a diff rebuild kit and some arms to start to keep on hand. Ill consider keeping a few wing mounts on hand too, not a bad idea. I will probably do the front and reach chassis braces and servo mount for stability.
I think the complete diff from Jenny's is about $5-$10 more than just the gears alone from Arrma. To buy what you get from Jenny's would cost you like $10-20 more from Arrma.Recommend researching the cost of the rebuild kit vs one from JRC. You can probably get the whole assembly cheaper than a rebuild kit.
IDK why everybody says wing mounts. I've bent my original, but not broken it. And the best thing I did after installing new bulkheads was to drill & tap the two screws at the bottom to accept M4 socket heads. Solid as a rock, and I've taken cartwheels that were easy over 10 hits. As far as arms, just get a set of RPM arms, don't waste your time or money replacing stock ones.My Notorious loves to ruin wing mounts but haven't broken a-arms. Also an extra diff or more to swap out. My front diff caused me the first grind after I jacked it up to punch 9. My recommendation is to not jack it up to punch 9 on old diffs...or be ready to swap and build. And thicker diff fluid is good to have and use.
I may just go with the RPM arms that way I can go with their rear mud guards as well.IDK why everybody says wing mounts. I've bent my original, but not broken it. And the best thing I did after installing new bulkheads was to drill & tap the two screws at the bottom to accept M4 socket heads. Solid as a rock, and I've taken cartwheels that were easy over 10 hits. As far as arms, just get a set of RPM arms, don't waste your time or money replacing stock ones.
I actually had mine do a ? on a pavement tumble, saw the wheel all locked out, thought I popped a turnbuckle rod end. Nope, the hub was flipped upside down. Just took a little nudge, and bam my RPM a-arms popped right back into place, straight as ever. I was astonished. ?I say the same thing about arms. I've never had to replace one. I have one sheared slightly from a metal culvert on my Talion but doesn't need replacing.
You're not trying hard enough. 10 hits is rookie status. I get a dozen before it even reaches the cliff?IDK why everybody says wing mounts. I've bent my original, but not broken it. And the best thing I did after installing new bulkheads was to drill & tap the two screws at the bottom to accept M4 socket heads. Solid as a rock, and I've taken cartwheels that were easy over 10 hits. As far as arms, just get a set of RPM arms, don't waste your time or money replacing stock ones.
