- Folsom, CA
- Granite
- Outcast 6s
- Outcast 8s
- Talion EXB
Took advantage of the amazing deal KingCobra had going on with the Outcast 8s and wanted to share my current build.
- Electronics
TP Motor 5670 1010kv
HobbyWing Max5
HobbyStar HS-6912HV
Spektrum DX3 - thanks @Moirae
Spektrum SR6100AT
-Other parts
RCP Hobbywing Max 5 Mount Plate
RCP HobbyWing Max5 Power switch mount
PerfectPass QS8 Plugs
RCP 56mm Dual Fan Motor Mount
(2) 40mm fans
30T Saga pinion - on order
Arrma 8s Stone Guards
Got the electronics installed last night.
Only ran into a couple of issues during the installation.
The servo saver screw was to long to go into the HobbyStar servo. Had to trim off about 4-5mm with my dremel. After that it fit perfect.
During installation and QC checks found a stripped thread going into rear diff holding the skid plate one. I cut some plastic tie straps to make new thread for the hole. Should hold up just fine.
Also found that the battery strap had a hole drilled through it when they put in the center tower brace. The brace wasn't fully secure to the chassis and the strap was stuck underneath it.
Sent e-mail to Horizon about the stripped thread. Will see what they say.
Currently have it setup on to run 25/39 gearing just because that's the only pinion I have available at the moment. Have a 30t on order. Once that arrives I will give it try and see how I like it.
Got some bad weather for the next 5 days but hopefully will get a chance to go out and test it.
Thanks to all who provided great knowledge on how to do this. I would be lost without everyone here!.
- Electronics
HobbyWing Max5
HobbyStar HS-6912HV
Spektrum SR6100AT
-Other parts
(2) 40mm fans
