The stock front springs are 27 lbs/in. The rear springs are 38 lbs/in. Assuming that is the front spring your pretty close to what they rate them at.Sorry this took so long! This is only comparative, not true compression rates. But I used a drill press set to drop 1” from the top of the scale.
But should give us a relative idea on the stiffness.
