Ben_W2503
- Outcast 4s
Tell me, If u've foubd a solutionI have yet to see a solution that fits a center diff in the 3s cars. You would have to design a different housing to replace the existing power module covers so that you could fit a diff where the slipper/spur assembly is now. You would also have to shorten the center driveshaft and probably find a new way to secure the power module assembly because you would no longer have room for the red block that currently serves that function (possible if your new module housing was secured by the same screw). In the SWB chassis you would be hurting for space to fit the motor at that point, probably possible but tight.
Dammit now I want to try to make it work.
