Greengaunja
Ise da by' dat burns da Senton........
ArrmaForum Fan
- Durham Region, Ontario Canuckistan
- Senton 6s
- Senton 3s
I'm not sure if anyone has actually done this but I can't seen to find anything. So I wanted to float an idea I plan to implement for the upcoming speed run season.
I've been doing research and looking at ways to crack the 150mph club. Short of just getting the XLX2 or squeezing in a Max5, what could be done? So I hit up Google and happened to come across Scorcheds new Trident shafts.
A good point is made in the description about how the stock shaft angles are not very efficient and how the Trident shafts compensate for it. I mean, it DOES make sense. But what if you eliminate the angles? Wouldn't that be more efficient than even the Trident?
I had plans for awhile to do a custom CF chassis. The main hold up has always been I don't want to fabricate one. I know nothing about doing CF from scratch or molds etc..but I know how to measure, even precision measurements with my trusty ancient Mitutoyo caliper and I know how to use quality tools and I know what cuts what. That's my area of expertise and that means cutting pre-made CF plates. But plates are flat and the bulkheads need front bulkhead kick. And I hate the idea of wedges for that purpose. Then I saw something amazing!
See it? You can buy the front bracket alone! So now we all know my next project. Here's where I'm going to change things you...
Every time I looked at my Senton, I always wondered why ARRMA would sacrifice drive train efficiency by offsetting the center differential just to center two tower braces? Granted maybe it's added strength that way but I highly doubt any strength is lost by lining the center differential up with the towers and offsetting the braces. Especially when those braces are reinforced with a T2T brace.
So the million dollar question fit you all is, would the drive train benefit with center shafts dead straight and with very little slop? Or did I throw something else off here? I'm not worried about the width of the chassis as I know I have room to widen it if need be. And both stock 1/8 Senton and the GT bodies wouldn't be effected.
