Hi, i recently ruined my rear input gear because of a lot of dirt in my gearbox. Now if I take a look at the crown wheel, I don't know what to think of it. Is this still usable or not?
Yes, it is the 6S version. The V3.This is the 6S version? Cause here is a pic of my ring gear for comparison.
What do you mean by engine 5k?What ever they say
Use only 5k closest to main gear / motor.
Also
Change the bearings in that motor to CERAMIC Bearings.
don't trust cheap China vendors who made these BLX,
What you need in front or Center is so different.
Right at ENGINE 5k
After that go higher in center and front
Never more than 5k at the engine
When i got the diff out, the gearbox was full of dirt.This is the 6S version? Cause here is a pic of my ring gear for comparison.
I don't know why your gear has such a weird wear pattern on the surface of the teeth.
But what do you mean by "where is your engine"? And "only 5k at engine?" I don't understand what you are trying to tell me.I have alot RC Cars from alot brands.
What i mean is what i write before !!!
Where is your Engine ?
I done alot RC Drifting also. There is some Front Wheel drivers ! SICK
aNyway. always 5000 at your engine.
Standart.
I have 2500k now right in my 1/8 onroad super car = EXTREME / Not RTR Arrma
I think he means only use 5k cst in the center diffBut what do you mean by "where is your engine"? And "only 5k at engine?" I don't understand what you are trying to tell me.
Mine looked similar when I took my Typhon 3S diff apart yesterday to get at the broken output shaft. I think that’s a normal amount of metal dust. At least it isn’t contaminated with sand or dirt.How does the standard oil look? Mine is a little bit grey-ish. Is this normal?View attachment 44160
Deuces ✌?iN this case guy is talking about standart rear diff
Make that metal covered
if not you are standard
I must leave this forum soon i believe.
Only Amateur Bashers?
Only Couple Serious
SOON BYE
I do want to be serious, but since I'm 16 years old, I don't have a lot of money and I cant replace everything to super expensive stuff.iN this case guy is talking about standart rear diff
Only Couple Serious
SOON BYE
I know that it can be hard if money is limited. The good part is that this appears normal wear and tear. You basically need only the input smaller gear and the larger ring gear. My 2 cents.I do want to be serious, but since I'm 16 years old, I don't have a lot of money and I cant replace everything to super expensive stuff.
Yeah, I know that site, but I live in Europe so the cost will still be high and I'll have to wait long. I was already looking for a pre assembled diff. I don't know if they come with the oil already applied. I will keep the other diff as a donor for parts.It is simply worn out. Cannot be be reused. Use a respectable grease on the new ring and output gear and make sure you shim properly. Replace and start over=more fun
Your diff internals look just fine ironically, color of fluid, the gears and all. I don't think diff fluid CST is to blame or will make much a difference. Let others chime in.
JennysRC.com may be a cheaper option. A preassembled diff may be more cost effective.
