recommend a good solder for battery connectors
N4SIR
Retired NYPD full time Basher
Fruitland Park FL
Kraton 6s, Mojave
jondilly1974
Speed running rookie, 3D printing fool
Toledo, OH
Granite, Kraton 4s, Typhon 6s, Typhon 3s
N4SIR
Fruitland Park FL
Kraton 6s, Mojave
jondilly1974
Toledo, OH
ok thanks which size?
  • 0.6mm/50g
  • 0.6mm/100g
  • 0.8mm/400g
Depends on what you’re soldering, but as a new guy I would go smaller diameter and roll until you know for sure what you like. You can easily buy some at a hardware store too. That way you can see what you’re buying.
N4SIR
Fruitland Park FL
Kraton 6s, Mojave
for right now my immediate project is changing and soldering new connectors to my lipos
jondilly1974
Toledo, OH
Anything will work. Thicker material will take (slightly) more heat to melt but will take less effort to fill larger areas. I think there is a greater chance of success as a new guy with thinner material. I have both. I have really thin stuff for board repairs, etc. I have big chunky stuff for large connectors. RC stuff is kind of in the middle.
Hmm lead free? I don’t remember why but I was always told by people with over 30years in RC that if I solder anything to use 60/40 solder nothing else - why are people recommending lead free here?
Safety. 60/40 is softer and may withstand impact better. But it has lead in it which is toxic. To me I would rather have to resolder something than bring lead into my house. I also solder indoors so the toxic fumes in the house is a no go for me.
Shazz4321
BigRock 4x4, Granite
As long as you’re sensible and don’t breathe in the lead fumes then it should be safe enough to work with in small doses. I solder in a garage and have a fan nearby to get a bit of cross-breeze going.
Non LEAD is obviously safer but as long as you’re safe it shouldn’t kill you...
r4nd0m
Milton Keynes, UK
Granite, Kraton 8S, Mojave, Notorious
The fumes are from the rosin, not the lead. You arent heating the lead hot enough to turn it into a gas. Afaik - just don't chew, eat or swallow it
Notorious J
Big Boy With Cool Toys
Granite, Outcast 6s, Typhon 6s, Typhon 3s
r4nd0m
Milton Keynes, UK
jondilly1974
Toledo, OH
Fair but d) surely applies - permissible exposure don't you think?
Like I said, I’m not risking it. You do you. I will still recommend to others to avoid what is possibly toxic. Better safe than sorry. What the harm?
crimsonfancy
A guy that won't give up easily.
South Louisiana
BigRock 4x4, Granite, Kraton 6s, Mojave, Notorious, Talion, Typhon 6s
If I can find with lead I use it in ventilation and take steps to reduce concerns. I have some stuff my dad and granddad gave me. Everything can be bad for us, right?
Key steps:
Don't huff solder fumes...no buzz, not worth it
Prepare to ventilate and take standard precautions
Wear a helmet when you ride your bicycle and only use curly light bulbs.
Support Greta because, "how dare you?!"
Only thing truly frail are feelings.
Captain Dirt
Acquitted for Life!
Murica
Granite, Kraton 6s, Kraton 4s, Voltage
Eh, I use lead solder all day long. So much easier to use and I've been using it as long as I've been soldering, over 2 decades by now.
