I was wondering the same thing. It might be possible. I think they are all on the same chasis with the biggest difference being the arms and driveshafts. Think i might go through the manual and see what parts are different.
I believe the Senton, Typhon and Outcast are on a shorter chassis and the Talion and Kraton are on a longer chassis. So I don't think you would be able to change it to a Kraton but could change it to an Outcast unless you bought the longer chassis.
I believe the Senton, Typhon and Outcast are on a shortener chassis and the Talion and Kraton are on a longer chassis. So I don't think you would be able to change it to a Kraton but could change it to an Outcast unless you bought the longer chassis.
The Outcast, Senton and Typhon use chassis AR320188 while the Talion and Kraton use chassis AR320197. So the Senton could easily be converted to an Outcast or Typhon. You could convert it into a Talion or Kraton, but you would need to purchase a new chassis.
