Savox 1270tg, works great on my Kraton at 7.4vI have never had a problem until the Nero. My guess is the power it puts out. Who knows really. Manufactures have different stuff in their manuals so we'll never really know.
Wow 7.4 V is high. Im only using 6V on ny Nero/ castle system because the diff brain servos can't handle much more according to Arrma.Savox 1280tg, works great on my Kraton at 7.4v
@Bic1090 the Savox 1231SG isn't waterproof but the Savox SW-1210SG is and if you're going to run in water or snow then I would certainly recommend getting a waterproof servo. Else you could always wrap the servo in a balloon, plastic dip, or even using corrosion x to waterproof a non-waterproof servo yourself.
Is 277 oz/in enough from the savox 1210 waterproof servo?
I'd rather buy one already waterproof than to save a couple dollars up front, and then have to buy the marine grease and plastidip later. I've never had good luck with the balloon trick.
Hahaha. Dude I totally feel ya!!
But it looks swert and should be a great servo. Keep in mind though, the lowest value it states is 620 at 6.0 V. I could be wrong but I thought the stock Nero esc only pushes 5.4V
Regardless that servo would be awesome!!!
I use this servo which is very powerful:KST X20-8.4-50 45KG High Torque Coreless Digital Servo Steering Gear [email protected] [email protected] [email protected] for monster truckSo far, everything I've read has stated the Arrma 200blx esc has a 6v BEC. That's not saying that if I hooked my meter up to it, it wouldn't read 5.4... but it is specified as 6v.
I don't think it'll fit. I could be wrong though. I had to trim the plastic plate above the servo to get my savox to fit, and that Hitec is a bit larger than my Savox according to the specs.Would this Hitec D840WP D-Series Mega Scale WP servo fit inside the Nero? Dimensions: 2.59 x 1.26 x 2.44" (66 x 32 x 62mm) It's WaterProof, it can crank out 417 oz at 0.11 sec/60 on 7.4V. and 333 oz at 0.14 on 6 V. Wow! And for $90 at TowerHobbies its appealing. I just think it would Not fit because it's larger than the other servos you guys are saying you use.
The Savox SC-1267 is not waterproof. You can waterproof it yourself or you can buy one like the Savox SW-0230MG that is waterproof.Hello! My big rock stock servo burn up or it is dead. I have Savox SC-1267. It is water proof but if it fits??
What's up all? So I need a new servo for my Nero.. What do you all recommend? I have heard about the Savox 1231SG and that it's a great servo, but it's not waterproof. Will this be an issue in the snow? I can't seem to find a high tq waterproof servo that's reasonable in price. Thanks!
