- Thread starter
- #41
The Copper Head 2s that came with the Kraton are almost worn out. I'm actually surprised how long they've lasted though, probably 35 packs and mostly on pavement. I didn't vent them, but I can tell the internal foam is starting to get soft from getting wet so I figured I'd give it a go. Found some info from Rich Duperbash on using a brass rod which made perfect sense to me so I practiced on the worn out Copper Heads and then moved on to the new DBoots BF. Interestingly one of the 6S BF wheels didn't have vents in the back side, the other three did. The LP Backflips didn't have wheel vents but were already vented in the tire, bonus.
I will be venting all tires going forward. When I drilled the holes in the Copper Heads water came out and it had been in there a while.
After that, I was bored, it was snowing and nasty out, so I took up some arts and crafts on the wheels.
Not sure what 10 year old they had glue the LP Backflips to the wheels, but good lawd teach that child to color in the lines!
